nesswill
Message 11 of 19
Re: SmartTalk problem
then this?
...if the world didn't suck we'd all fall off...
nesswill
Message 12 of 19
yes I can see the bill and everything else.
Message 13 of 19
Did you then use your mobile to setup SmartTalk, using you MyBT id and password? From what I remember, you activate it initially from the phone, and it places a call to your home phone number as a security check.
As mine is already setup, my screen is different.
Message 14 of 19
nesswill
Message 15 of 19
yes it did put in phone call code then put in text code
thanks
nesswill
Message 16 of 19
hi yes read them all and none allpy (BT account problem)
Thanks Ness.
Message 17 of 19
I would try the helpline number, unless anyone else has any suggestions.
nesswill
Message 18 of 19
Keith, thanks for all the help, i will call them tonight when i get home.
Regards,
Ness.
Message 19 of 19
Sorry I was unable to help any more. I was one of the triallists, and set mine up at that time, but it was a while ago now. I only have one mobile registered against it.
