Message 1 of 5
Smarthub 2 IPV4 Configuration
Apologies if this has been "addressed" already (excuse the pun) but ....
My smarthub 2 was set up so that the default ip was 192.168.0.1 nd had a number of devices on my network with static ip addresses (set up on the devices themselves).
I had some broadband connectivity issues and in BT's wisdom they remotely did a factory reset on my smarthub 2.  So now my access to the hub has reset to 192.168.1.254.  I have tried changing it to 192.168.0.1 and changing the server address range to 192.168.0.2 to 192.168.0.253.  Whilst I can see and access the devices with static IPs the connection to the broadband keeps dropping and the sky box doesnt like it.
It seems the only way I can keep a stable internet connection and connection to my sky box is by leaving the SH2 at the default settings.  Has anyone else had these issues or am I forgetting something?
Thaknks
4 REPLIES 4
Message 2 of 5
Re: Smarthub 2 IPV4 Configuration
Seems extremely odd, can't see why a different IP range should cause instability, it should either work or not. What is actually dropping, DSL or LAN?
Did you remember to turn off Smart setup again after the reset?
Message 3 of 5
Hi,
Its the connection to the internet so DSL.
I didnt do anything with "smart setup" - dont remember changing anything there when I initially set it up.
I'll turn it off and try it now.
Message 4 of 5
Smart setup won't affect the DSL connection, but might give you problems with the Sky box. I think the instability is probably coincidence, I really can't see how LAN IP range can affect the DSL connection.
Message 5 of 5
I agree. Still the same problem. Happens with two different SH2 Hubs  I have. I must be missing something.
Im at the point where’s Im beginning to think it’ll be easier to change all my static iPs and my subnet to match that of the router
