leonkenworthy
Message 31 of 65
Re: Smarthub flashing purple light of doom?
Fair enough!
leonkenworthy
Message 32 of 65
Tried my friends router and it still isn't picking up the internet. Seems the hub isn't the problem. The other router picks up everything else except the internet. Must be a line fault.
gg30340
Message 33 of 65
You are sure it is a VDSL Modem/router and not an ADSL modem router? ie your friend used it on a fibre connection without an Openreach modem.
leonkenworthy
Message 34 of 65
Yeah it came with a additional router thing for Fiber connection, plus as plusnet is a BT company the settings are pretty much the same. Also my engineer friend noted the purple light indicates hub is fine just connection missing.
licquorice
Message 35 of 65
Hub and fine in connection with the HH6 is an oxymoron. Smiley Happy
gg30340
Message 36 of 65
I would agree with licquorice's remarks about HH6. If you are sure that you set everything up correctly with the Plusnet equipment that only leaves a problem with your actual connection and assuming the engineer fixes it, you won't then need to wait for a replacement hub.
Personally I would hold onto the Plusnet equipment if your friend will let you. You may find it better than the "Smarthub".
leonkenworthy
Message 37 of 65
A week of no proper internet is like cutting of a toe. It's not necessary to get by but makes everything uncomfortable hahaha.
kitbooth
Message 38 of 65
Just come back from five days of flashing purple. India went through all the script resetting the hub etc to no avail and dispatched a very helpful engineer who arrived yesterday morning. He did all the line tests etc and tracked a fault in our port at the exchange which stopped the hub syncing.
Having moved everything to a new line and reset the cabinet connections purple (eventually) went blue at 29Mb and then snuck up to 46 by evening.
Now to setup the house wifi (once more) as everything changed with the resets!
MorgaineD
Expert
Message 39 of 65
@kitbooth, the obvious question from that is, why didn't BT's remote diagnostics pick up a fault at the exchange?
It's no good for BT and a misery for its customers when engineering diagnostics are inadequate.
kitbooth
Message 40 of 65
After quite a while of 'diagnostics' it was originally declared a neywork fault and, after escalation, not a network fault but possibly a fault at my property.
You would have thought that a faulty port should have shown up where ever the diagnostics originated!
A strange byproduct of the diagnosis and resetting of the hub has been that the wifi password has reverted to the original! When I had the first of the 'destructive' updates last month it would not let me proceed without changing the password to one different from the original 'preset' on the pull-out card.
Now it has gone back to that and BT wifi in all its wonderful versions is re-enabled.
