MrBelter
Expert
Message 21 of 25
Re: Snr margins
74179kbps is 72.44Mbit not nearly 76Mbit
ironman123
Recognised Expert
Message 22 of 25
Re: Snr margins
I have ti disagree with you there MrBelter.
74179 x 1024 = 75959296 = 75.959296Mbps
The 74179 is kbps,to convert to mbps you times by 1024 [1 kbit = 1024bits].
DonDino
Expert
Message 23 of 25
Re: Snr margins
I know it's an old topic but...
You **divide** by 1024, not multiply.
You'd multiply Kbps x 1024 to convert to bps (bits), but you divide Kbps / 1024 to convert to Mbps. So indeed, 74179Kbps = 72.44Mbps.
legitimise_sailing
Distinguished Expert
Message 24 of 25
Re: Snr margins
I think you're referring to Kibibits, not Kilobits
To say thanks for a helpful answer, please click the white star
Bald_Eagle1
Message 25 of 25
Re: Snr margins
I believe Kbps is simply divided by 1000 to get Mbps
i.e. 80000 Kbps = 80 Mbps.
