Distinguished Guru
Message 41 of 52
Re: What's going on this time:(
Why would the hub show this and then with in 2 mins be fine?
-+-No longer a forum member-+-
Message 42 of 52
Hi DS I have seen this before my self normally a restart solves it's one of the unexplainable bugs in the firmware
Distinguished Guru
Message 43 of 52
Thanks John, but it's never done it to me before, till today. I didn't need to restart, it somehow cured itself:|
Message 44 of 52
not sure about the cause it appears as if it is a firmware bug like the H2's fec reading it is also possible that it could also be an exchange software problem that appears randomly
Distinguished Guru
Message 45 of 52
Again thanks
I might stick my spare 3b in it's place to see what happens with that one, but as I also thought it may be an exchange glitch, I've just fired off an email to the guy that dealt with my hot hot hot VP issue at ELTC, just in case there is a problem at the exchange. I'm aware that my exchange is likely to give me more hassle:(
Though I've just had an auto reply and he's out till Monday, so I'll have to wait and see what he thinks.
Message 46 of 52
would be interested in the outcome
Distinguished Guru
Message 47 of 52
Re: What's going on. Hub usage reset again
@DS wrote:snipped
@DS wrote:snipped
How can my hub reset the amount of data received without me resetting the hub?
Earlier on today it was way more than the 0.1GB it's currently showing - the hub has been up for over 9 days!
After 7+ days, the amount of data received has reset.
The amount transmitted has carried on counting as it did the last time.
So my HH3 has an uptime of 26 days and 13 hours the amount shown transmitted has gone down to 1.0GB, the amount received has reset to zero. It does look like when I hit 5GB (received), this triggers a reset
No reply from ELTC regarding the email I sent:(
Message 48 of 52
That's interesting DS have never seen that before although I have heard reports like yours before but never seen the evidence like yours
Distinguished Guru
Message 49 of 52
Indeed John, neither have I.
I'll reset my hub at midnight and monitor this throughout next month (taking in to consideration the arrears on the BB usage monitor).
Message 50 of 52
DS
as you are still on BT can I assume someone kind person sorted out your billing problem - quicklySmiley Wink
