DS
Distinguished Guru
Message 21 of 52
Re: So I had an engineer visit and I'm not happy
@Aarong wrote:
I'm not to sure how much you've used but doesn't it reset after 5Gb of usage? Mine does.
Hmm, interesting.....
Does you amount sent also reset? - Mine hasn't
@imj. I'll have a hunt around later on;)
-+-No longer a forum member-+-
Aarong
Guru
Message 22 of 52
Yea both sent and received resets after 5GB of usage.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
DS
Distinguished Guru
Message 23 of 52
Argh, so yours is different. I know a dept from BT was looking at my hub info earlier, I wonder if it can be reset at their end.....:|
Aarong
Guru
Message 24 of 52
To my knowledge i don't think it can, although i can't be too sure.
DS
Distinguished Guru
Message 25 of 52
@DS wrote:
@DS wrote:
Update.
I have a "roasting hot" vp.
Being swapped over sometime on Monday.
Forgot to post this yesterday:o
For a reason that is being investigated, the planned works didn't happen:(
😞ALL the VP's are hot!😞
Apparently the capacity has been increased at my exchange - I'm to monitor this, send in random tests and will be called tomoz
Webby
Message 26 of 52
Bit of a nightmare, seen it a few times though 😞
I assume you're in a very small exchange?
DS
Distinguished Guru
Message 27 of 52
Nah, I'm in my house:D
(approx 5,800 residential premises and 200 non-residential premises).
DS
Distinguished Guru
Message 28 of 52
A grumpy update
Exchange regraded:)
speed tests were improving:o after the recent multiple reports of low results:(
at 21:05 it took a dive to 3.54mbps:o
Tried skype tonight at 10pm ish, thought all was well and then had the effin BB too slow warningSmiley Mad
don't tell AQ;) - roll on the 19th!
Webby
Message 29 of 52
Very bizzare that every VP on an exchange of that size are hot :s
DS
Distinguished Guru
Message 30 of 52
Tell me about it!!Smiley Mad
I'm due another call tomoz from ELTC, but I thinks we've gone as far as we can with this:(, well with ADSL via BT anyway:|
