Showing results forΒ
Search instead forΒ
Did you mean:Β
madge80
Message 1 of 12
So fed up with BT, dropping connections.
hi guys
im not looking for faster internet im looking for internet that does not drop out.
The internet drops out and a yellow glow appears over the wireless connection symbol in the bottom right of my laptop screen. when i try to reconnect to my BT homehub it says windows cannot connect to BT homehub. i need to restart the hub at at mains to be able to connect again 😞 thinking of leaving BT and moving to sky. very little reason to stay with BT.
my job needs for me to online skype/msn etc and when internet keeps dropping out its really hindering.
i have down loaded inssider2 and switched to channel 9 as it seemed to be the least used channel by other networks around my house.
Dom
11 REPLIES 11
Hellohound
Message 2 of 12
Re: So fed up with BT, dropping connections.
It's your fault im afraid, always is and always will be when it comes to BT.
Distinguished Guru
Message 3 of 12
That is a very helpfull post, I will thank you for the OP
toekneem
(EASBF)
Distinguished Guru
Message 4 of 12
@madge80 wrote:
hi guys
Dom
Hi madge.
I am not an expert on wireless , but do you have the latest drivers for your wireless card.
Do you know what type of card you have, b/g/n
You could also try setting the wirelss interface type in the HH to 802.11 from b/g/n to n only or try b/g
Do you need to connect wirelessly, connecting using ethernet leads always gives a better connection, plus you could also look into using Homeplugs/powerline adapters.
I am sure there are other more experienced wireless users who will come along with a bit of advice.
toekneem
(EASBF)
madge80
Message 5 of 12
hi there, even if ur not an expert i apprecaite you helping me πŸ™‚ im not too sure how to update drivers, i will google that now and try to update my wireless drivers. although my brother bought  a new computer and the same thing was happening to him. you would think the HH could support 2 computers πŸ˜•
i do not know what kind of card i have my , my laptop is an acer aspire 5735z though.
yes i need a wireless connection and so does my brother 😞 dont knwo what Homeplugs/powerline adapters are...to google i go πŸ™‚
Distinguished Guru
Message 6 of 12
Hi madge.
Just checked your wireless card should be 802.11a/b/g/n for that Acer. Your brothers is a new comp so should be the same.
You can try Windows update to see if it will find new drivers, and you have tried Insider to find less congested wireless channels.
powerline adapters are like these; http://www.devolo.co.uk/consumer/dlan-mains-supply-network-fastest-200-mbit.html?l=en
Another way might be a different wireless router.
But wait for some other replies before you spend money, maybe unnecessarily.
toekneem
(EASBF)
gouledw
Recognised Expert
Message 7 of 12
I echo what Tokeneem has said, the Wireless G will tend to be more stable than the N in some cases, even if your devices use Wireless N it can lead to some instability in the connection, as you have said dropping, what I would suggest is taking a look here, and then monitor the connection for say a few hours and see if it does or does not drop out.
madge80
Message 8 of 12
ok changed to b/g...it was set to b/g/n.
the information here has been really helpful, i hope it sorts the problem out its really annoying me. i will update later 2night (to see if these changes has effected anything)
madge80
Message 9 of 12
just a quick update - wanted to leave it a few days to see if i was nt dreaming!
changing from b/g/n has really improved the stability.
thanks guys.
OAP41
Message 10 of 12
Hi, Have read your enquiry, and if it is any comfort, I too am experiencing so called 'dropping' and B T remain silent.
The only difference being my system is Wired not Wireless.
Planning to switch to cable, although in the past I have been impressed by BT.
