Message 1 of 60
So who has cancelled their BT vision sub?
Just rang to enquire as my minimum term is almost up and was told that if I cancel the BT vision subscription (but will keep Infinity) then my Youview box will be useless as a PVR.  No pause, record, on demand etc.
This is not what I was told when I signed up.
It seems lots of people are being told that.
Is it something they have been told to say to avoid losing subscriptions, or where has this info come from?
Has anyone actually cancelled the vision sub yet?
59 REPLIES 59
Distinguished Guru
Distinguished Guru
Message 2 of 60
Re: So who has cancelled their BT vision sub?
You will lose your BT player services and any BT  EXtra/Sports channels on the box. Any recordings (not really  relevant yet as we can't record the internet channels) from the BT channels would probably/possibily not be playable after you end your subscription.
Otherwise it will act as a normal Humax Youview box and you will be able to use as a Freeeview HD PVR and the available players when you connect to the internet. (Youview broadband usage would be countable against your provider usage limits).
Only grey area I can see is future box fimware/software updates.
As far as I'm aware the box will not function as a PVR only applies to the original BT Vision (old style Cardinal ?) systems and not to either the new look Vision or Youview boxes.
Distinguished Guru
Message 3 of 60
Cardinal was the trial name for the new look on the BTVision box.
I'm going to ask a Mod to clarify this as it is being raised far too often and as far as I am aware is totally wrong and the box will function as a PVR.
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Message 4 of 60
Same thing happens when you cancel your Sky subscription. The Sky box will receive Freesat, but you lose Sky+ PVR functionality. Why is this surprising with BT YouView?
Distinguished Guru
Message 5 of 60
Seamaster, you can't compare the two. The sales rep is wrong it will work.
Helpful Post?
Moderator
Moderator
Message 6 of 60
Good afternoon everyone,
We're just looking into this and we'll post back shortly Smiley Happy
All the best,
Robbie
Message 7 of 60
Mine's up around the 5th November. I've already called to cancel my sub. Thanks for the heaviliy subsidised PVR though BT :-). Shame the YouView box is too good to go on a bonfire, so eBay will have to do.
I'm going back to Sky.
Edit: I was also told when I cancelled that the YV box would be unable to pause and record
Moderator
Moderator
Message 8 of 60
Hi guys,
Thanks for the patience with this. Just to update you, we have checked and we can confirm that the box will continue to work as a PVR for Freeview channels.
Cheers
David
Distinguished Guru
Message 9 of 60
Thank you David. That is exactly what we knew to be the case. It is unfortunate that the wrong information is being given out.
Helpful Post?
Message 10 of 60
So do all the on demand services still work (apart from the BT app?) such as iplayer, itvplayer etc?
ie, is the only thing I lose by cancelling is the BT app?
