Newbie
Message 1 of 3
Socket for bband and phone
I'm decorating the living room so the box for broadband and phone has been taken off wall temporarily. Changes to the room mean a radiator will go where the box is. The cable from the main entry point/box into the house is fine as new position is actually closer. Am i ok to just move it or do i have to get BT out to do it (not fussed about resizing cable)?
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Socket for bband and phone
you cannot move your master socket that is Openreach property and is a chargeable call (£130) if it is an extension socket then you are allowed as extensions are your responsibility
Recognised Expert
Message 3 of 3
You can move it, its not that hard. If you find it doesn't work when you put it all back together you will face a charge for bt to come and put it right though.
