ZooBurner
Message 1 of 6
Software Update box wont update
Hiya there
I've just got my YV box today
I noticed thread that said the latest update should be as follows ..
Manufacturer Software: 10.6.0
Component Software: 1.3.4
Platform configuration: 332
ISP Configuration: 1
What I actually have is
Manufacturer Software: 10.4.0
ISP Configuration: 27
I have tried to manually update, but it keeps telling me I already have the latest update.
5 REPLIES 5
drhowells
Recognised Expert
Message 2 of 6
Re: Software Update box wont update
Hi, YouView updates are sent in a staggered roll out. This means that the updates are released to different people at different times, so that their servers are not overloaded if everyone tries to download at once. So, basically, as long as your box is left with power overnight and has an internet connection, you will get the update in time.
ZooBurner
Message 3 of 6
Hiya there
Many thanks for your reply, and I do understand what you say about a 'roll out' but would that still apply to a manual update ?
Andy
drhowells
Recognised Expert
Message 4 of 6
Yes it does. They have an update server(s) that will release the update to certain users at certain times. So, you can do a manual update, but if the update hasn't been released to you, you won't get it.
This is why the people who bought the box in a shop get the updates first, usually followed by BT and then Talk Talk. But, they will also limit the people in each of those 3 groups as well.
ZooBurner
Message 5 of 6
Hiya there
Thank you for your reply, I will sit it out and wait 🙂
Andy
ZooBurner
Message 6 of 6
Manual update succeeded as soon as the service (BT Vision widget) started working.
