Message 1 of 7
Solid Orange Light on smart hub
Hi all
I've recently had my by activated and had it confirmed as active. However, even though there is a phone connection, the smart hub remains solid orange .I've been through technical on the phone and done everything they have suggested .
All they've said now is to wait 48 hours and if it doesn't fox itself I'll have to arrange an engineer visit to come look at it which could mean another wait.
Is there anything I can do to try and fix this? Would be great to have access to everything in paying for!
Cheers
Matt
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Solid Orange Light on smart hub
Have you tried the Troubleshooting Guide
Message 3 of 7
If you have tried connecting to test socket with a filter and still no blue light then you need engineer visit to get you connected
Message 4 of 7
Yes i've tried that. I spent a good time on the phone to the technical guys who made me do all sorts which resulted in no change. I was then told to wait 48 hours before calling abck to ask for an engineer.
Surely if they are saying it's all active and i have a phone signal but the BB isn't connecting then there's another issue?
I've tried using different micro filters, plugging it into the extension sockets, resetting the router etc etc...
Message 5 of 7
you need an engineer visit to get connected
Message 6 of 7
If the light is solid orange, then the Hub has a broadband connection but the login details it's looking for to connect you to the internet are wrong or missing. Dial 17070 from your landline and make sure that the phone number on the line is what it should be. If it's different, the engineer will nip to the cabinet and connect you to the correct number. If the number's right, it may be a broadband specific fault which the engineer will be able to sort. If you've recentrly switched providers, sometimes your new line is connected to what the system thinks is the right routing, but is has actually changed over time due to faults and errors in recording. So you're actually still connected to your old circuit.
Message 7 of 7
Hey, just for any new visitors to this post.
If you have issues with the lights on your Hub (regardless of which model), please visit https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/what-do-the-lights-on-my-bt-hub-...
This will give you information on what the lights mean, with hints, tips or advice on fixing the issue.
On the newer Hubs, a solid orange light will generally indicate you need to connect to the Hub, open a web browser and follow the on-screen prompts.
