Aarong
Guru
Message 11 of 22
Re: Solid for a month. Now dropped and erratic...
Yea it's using my Mac i have the issue with, however, i have try an alternative P.C and still have the same issue, unless it's an issue with the Speedtester itself?
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
john46
Message 12 of 22
it happens when the testers server gets over loaded all you can do is keep trying
Aarong
Guru
Message 13 of 22
Tried constantly myself john over the past few days and still can't get a reading, it does the test, but just doesn't send to server and show me results.
hifistud
Message 14 of 22
At the risk of sounding "me too", erm, me too...
hifistud
Message 15 of 22
And it's still bust - is anyone looking at this, does anyone know?? Mods??
iSean
Message 16 of 22
My Speed seems to be a solid 50mb at the moment. No change on upload. I was getting 61 but it seems they have taken 10mb off me for no reason. Probably because I can't cancel and move elsewhere.
To be fair I was predicted 52mb but why did I get 61mb.
Oh well. Still better than my 6.1mb i was previously getting on adsl.
Bullitt
Distinguished Expert
Message 17 of 22
its not for no reason its automated so some reason was detected
Webby
Message 18 of 22
As above, some instability/noise/errors were identified by DLM. So to protect the stability and integrity of the line, it lowers the speed.
I must have said this 100 times on these forums.
iSean
Message 19 of 22
10Mb is a bit of a drop though, wouldn't you agree? the odd mb I appreciate but just to take 10mb away seems a bit drastic.
Oh well.
Webby
Message 20 of 22
Depends what the cause was.
