iSean
Message 1 of 22
Solid for a month. Now dropped and erratic...
Was getting a solid 60 down now its dropped to 50 then to 34. Whats happened?
Wired and on a mac. Nothing has changed at all?
Cheers
21 REPLIES 21
Greggaz
Message 2 of 22
Re: Solid for a month. Now dropped and erratic...
Could you do a speedtest and link it to here
http://speedtest.net
Knowing Broadband since 2000
"If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’"
john46
Message 3 of 22
you need to run the full bt speedtest so we can see your IP profile speedtester.bt.com
hifistud
Message 4 of 22
That would be easier to do if speedtester wasn't broken. It gets to 100% on the upload and then just sits there with its digital thumb up its digital ***, doing nothing. Can somebody please fix it?
john46
Message 5 of 22
working fine here has been for weeks now
hifistud
Message 6 of 22
it's not just me - there are other reports, too...
iSean
Message 7 of 22
I can't do a Full BT test as i'm on a Mac.
Cheers for the help guys
iSean
Message 8 of 22
ignore that Mac thing I said. I had Java disabled. Test still won't work though. Just brings ups a system error after going the upstream test
Aarong
Guru
Message 9 of 22
Same has happened to me, can't run a B.T speedtest to look at my profiles.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
hifistud
Message 10 of 22
you on Mac, too?? I am, OP is... wonder if that's the problem. Srange how it gets both up and down done and then barfs at the end. Maybe its disk is full...
it gets to 100% on the upload section, sits there for a while and then comes back with: "
FAQ
null
The system is currently busy. Please try again shortly, however if this problem persists, raise the issue with your service provider
