Hanuman
Message 1 of 2
Solved - Powerline Adaptor Missing Channel Issues BT YouView
Thought I would post the fix here in case anyone else has the same issue. There's a firmware update available for some TP Powerline adaptors, (Google these to check yourself with the make and model). I changed this and the QoS (Quality of Service) settings on the powerline adaptors themselves to allow multicast / audio / video.
There are several posts about this subject, but one here is particularly useful.
1 REPLY 1
DavidM
Moderator
Moderator
Message 2 of 2
Re: Solved - Powerline Adaptor Missing Channel Issues BT YouView
Thanks for the post @Hanuman. Appreciate you taking time to do that.
Cheers
David
