I'm just wondering what BT might suggest next with this......
For several months now my BT Infinity connection has been disconnecting and reconnecting several times each day. It took a while for BT Support over the phone to take this seriously after which they: (1) Carried out tests and resets from their side without any success; (2) Replaced the Hub6(TypeA) with another Hub6 (TypeA) without any success and (3) Sent a BT engineer to my home who could find no issues but as a matter of course replaced the two phone sockets in my home with the latest NTE5C models and following a conversation with another BT dept who could see the number of disconnections I had experienced did connect me to something different at the cabinet.
However, nothing has changed, I still experience 4 connection losses each day, some always at the same time. For example with a minute or so the connection will always drop at 06:30h and increasingly at 16:30h too.
I'm due a follow up call from last weeks engineer visit this Thursday. Is there anything else that can be done??
Thanks.
Solved! Go to Solution.
It's been a week now since BT Engineer visit and BT Level2 support followed up today on my connection problems.
I'm immediately told everything is ok now and they would like to close the call. I ask how can it be okay when I continue to have an average of 3 dropouts each day and an average connection period of 7hrs 15min.
"This is normal", she says. "The line will test itself each day, nothing I can do", she continues. "You should just use wired connections and not wi-fi". I struggling to believe what I am hearing now!!
Until a few months ago I wasn't having these problems so I don't really believe her story.
Can a BT Mod offer any guidance here please? I've been told BT Wholesale will look again and Level2 will contact me again next week.
It could well be just the hub but I don't see why I should pay for a third party hub, no matter how cheap, when I'm paying for a service that should have equipment that works.
Here are some stats:
BT Hub 6A
+084316+XXXXXXXXXX
SG4B1000B316
31-Aug-2017
1.0
1.64.0
0 Days, 4 Hours 53 Minutes 18 Seconds
7.98 Mbps / 34.15 Mbps
8186 / 40981
6.1 dB / 6.2 dB
22.7 dB
0/38
G_993_2_ANNEX_B
Fast Path
110624 MB Uploaded / 143920 MB Downloaded
bthomehub@btbroadband.com
Active
BTHub6-XXXX
Smart (Channel 11)
BTHub6-XXXX
Smart (Channel 36)
WPA2 (Recommended)
Mode 1
On
84:XX:XX:XX:XX:XX
7.33.1
and this......
Telephone Number 0XXXXXXXXXX on Exchange XXXXXXXXXXX is served by Cabinet 6
VDSL Range A (Clean) | 43.7 | 32.4 | 8.4 | 5.9 | 30 | Available | -- | -- | Yes | -- |
VDSL Range B (Impacted) | 34.5 | 17.4 | 7.8 | 4.3 | 13.1 | Available | -- | -- | Yes | -- |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | -- | -- | ||
WBC ADSL 2+ | Up to 7 | -- | 6 to 8 | Available | -- | -- | -- | Yes | ||
WBC ADSL 2+ Annex M | Up to 7 | Up to 1 | 6 to 8 | Available | -- | -- | -- | Yes | ||
ADSL Max | Up to 7 | -- | 6 to 8 | Available | -- | -- | -- | -- | ||
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- | -- | Yes | ||
Fixed Rate | 2 | -- | -- | Available | -- | -- | -- | -- | ||
VDSL Multicast | -- | -- | -- | Available | -- | -- | -- | -- | ||
ADSL Multicast | -- | -- | -- | Available | -- | -- | -- | -- | ||
Bridge Tap | N | |||||||||
VRI | N | |||||||||
NTEFaceplate | N | |||||||||
Last Test Date | 20-05-2017 |
BT sent a second Openreach engineer to my home but still no joy in resolving the issue.
BT are now going to send a 'Fibre Expert' to my home for a more detailed investigation.
Yesterday, I connect my old Hub5, suspecting the router could be at fault. However once again disconnections again and at very similar times to Hub6 so I can rule out the hub as at fault here.
I'm now suspecting something in my house is causing this. Been reading about REIN and SHINE! Has anyone ever found SKY+ HD boxes to be a cause for a dropped connection? I have two such boxes that are wirelessly connected, including the phone line which instead of using a hard wire connection uses wifi data to whatever SKY do when they remotely access your box.
Not heard of any issue with the Sky boxes but who knows?
You seemed ready to purchase an Openreach modem (about £25) but don't want to spend a little bit extra for a more update solution.
Personally I've never used ISP supplied equipment other that a modem as all of them are cheap and tacky in a platic box that looks trendy. (if you like cheap and tacky).
Pehaps it's because I want a rouer that does what I want it to do rather than what the ISP thinks I want. One size never "fits all".
Your choice though. I suppose you'll have to wait for the "fibre expert". AFAIK they are actually called Broadband Boost engineers, but what's in a name.
