Message 1 of 4
Sorting emails in Inbox by Unread and Read
I can sort by attachment, date etc but I cant find a filter to allow me to display only Unread (or Unread first, and then Read). Any ideas how to do this?
3 REPLIES 3
Message 2 of 4
Re: Sorting emails in Inbox by Unread and Read
Change your view using the Change View at the right hand side and select "Right". The filter (icon that looks like a funnel)  will then give you the option to sort by Read or Unread.
Message 3 of 4
Thanks, that all works. I guess that the filtering options are not all available to every view, and I happen to use 'None' as my default view.
Message 4 of 4
If I recall correctly, if you revert back to the "None" view it retains the filter that you have set up although I can't recall if it retains the setting after you have logged out and then log back on and start a new session.
