nuggies5
Message 1 of 14
Speed Dropping Around 4.00pm
Hi
Having a problem with my Infinity 1 Broadband.
Speed during the day is great,but come around 4pm the speed jusy drops dramatically
Here are some pics to Show the problem...Screenshot 2016-05-03 09.49.04.jpgScreenshot 2016-05-03 14.15.07.jpgScreenshot 2016-05-03 21.00.07.jpgScreenshot 2016-05-04 13.37.06.jpg
As you can see there is a problem
How to i go about getting someone to look at this...
Ian
13 REPLIES 13
imjolly
Message 2 of 14
Re: Speed Dropping Around 4.00pm
Looks like congestion. Which exchange are you on?
nuggies5
Message 3 of 14
Hi
Im on the Halifax Exchange
yan101
Message 4 of 14
Something looks wrong on the router stats. Max attainable upload speed and attenuation. Im no expert but im sure someone will come along and let you know what it means
Webby
Message 5 of 14
Nothing wrong with the line stats at all. OP is on Infinity 1 40/10.
I suspect a congestion issue as mentioned above. Mods should be along soon however, can you please run the further diagnostics test on the btwholesale speedtester using an Ethernet connection.
imjolly
Message 6 of 14
There is no congestion reported for the Halifax exchange according to mods so see if they can find out why sped drop at peak times. Mods will post here with contact us link.
After completing the email NOT PM then you join a queue of other customers waiting for mod help. The mods will get back to you in 2/3 working days either by phone or email
DanielS
Moderator
Moderator
Message 7 of 14
Hi @nuggies5,
It'd be best if you spoke with one of the team here so we can go over everything with you. @imjolly is right about the Halifax exchange. There are no reported problems with it. That could point towards an issue with your line individually. You can reach us by clicking on my username and then on contact the mods. It takes us a couple of working days to pick it up but we will be in touch.
DanielS
yan101
Message 8 of 14
So the upload data rate of 9999 and signal attenuation of 0.0 is normal? Legit question as i have no idea what signal attenuation is
nuggies5
Message 9 of 14
My first thought was congestion for the simple reason my speed is great during the day, but terrible come evening,so i presume my internal wiring is okay.Never had a problem with speeds before ,just these last 5 weeks or so.
I have contacted the Mods,hope we can get this resolved
Ian
imjolly
Message 10 of 14
@nuggies5  Is on infinity 1 with 40/10mb connection. Hub 5b always shows 0 for signal attenuation firmware bug
