EchoLeopard
Message 1 of 4
Speed Problems with Infinity - Max Data Rate the Issue?
Hello! I am having some serious issues with my download speeds at the moment. I have been on the web chat several times, on the phone several times and promised a few Engineers which have been canceled, having a look at my BT Home Hub, is the Maximum Data Rate the issue? We should be on BT Infinity 2 (76mb) but am never getting above 20! Otherwise can anyone see any other issues? Many thanks!
Data rate:
7.36 kbps / 24.45 kbps
Maximum data rate:
7357 / 23524
Noise margin:
6.2 / 6.1
Line attenuation:
23.7
3 REPLIES 3
Webby
Message 2 of 4
Re: Speed Problems with Infinity - Max Data Rate the Issue?
What problems are you having?
Can you run this check for your telephone number and post up a screenshot of the result - http://www.dslchecker.bt.com
EchoLeopard
Message 3 of 4
Hi! We are only getting internet speeds of around 15-20mb/s on BT Infinity 2. Thanks for your help!
Webby
Message 4 of 4
Firstly you should downgrade to Infinity 1 as you're never going to get above the max speed of Infinity 1.
Are you connected to the master socket? Or an extension?
