Hi I’m on Fibre 100 with max speeds of 150mbps (according to BT) my actual speeds wired or wireless are around the same topping out at around 128-131mbps
I was wondering if I opt for Fibre 900 will I reach those speeds? Or will they stay around what they are now? As I’m not currently achieving 150mbps as my package states
thanks
150 is sync speed not throughput.
Sync speed what is that?
and also will I achieve speeds of 900mbps if I upgrade?
Sync speed is the raw speed before overheads. Barring network congestion you will always get full speed with FTTP (minus overheads of course 😊).
