Newbie
Message 1 of 14
Speed between router and laptop is nowhere near actual braodband speed
Hi,
I currently have a bb speed of 18 - 20 mb.However when I am downloading on my laptop teh max speed i will download is 2mb.This is for both wired and wireless connections.
Any idea what the problem could be?
13 REPLIES 13
Expert
Message 2 of 14
Re: Speed between router and laptop is nowhere near actual braodband speed
You need to post both the adsl stats from the router and the results of a BT speedtest but from what you say your IP profile could be stuck at 2000kbs
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
Newbie
Message 3 of 14
Hi,
Where and how do I get teh ADSL stats from and how can I sort out the IP profile.
Thanks again
Message 4 of 14
in order to help please can you post the adsl stats from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) http://speedtester.bt.com and post the results .
are you connected directly to the NTE5 master or test socket or to somewhere else? Do you have any phone extension sockets in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
Newbie
Message 5 of 14
Hi,
Below is my ADSL stats;
Connection information
<script type="text/javascript">// createTable("normal", trClass, td1, td2); // </script>
Line stateConnected
Connection time1 day, 0:19:03
Downstream18,840 Kbps
Upstream828 Kbps
ADSL settings<script type="text/javascript">// createTable("normal", trClass, td3, td4); // </script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)6.3 dB / 10.3 dB
Line attenuation (Down/Up)16.5 dB / 7.8 dB
Output power (Down/Up)21.1 dBm / 12.4 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)146527 / 1
CRC Errors (Down/Up)242 / 2147480000
HEC Errors (Down/Up)nil / 98961
Error Seconds (Local)
233
Message 6 of 14
great 18mb connection and looks ok.  just need btspeedtester now
Newbie
Message 7 of 14
BT speed test results
Download  Speed
 13945 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
Download speedachieved
during the test was - 13945 Kbps
For your connection, the acceptable
range of speeds is 4000-21000
Kbps
Additional Information:
Your DSL Connection Rate
:18840 Kbps(DOWN-STREAM), 828 Kbps(UP-STREAM)
IP Profile for
your line is - 16000 Kbps
2. Upstream
Test: -provides background information.
 Upload Speed
 539 Kbps
0 Kbps828 Kbps
>Upload speed
achieved during the test was - 539 Kbps
Additional
Information:
Upstream Rate IP profile on your line is - 828
Kbps
Message 8 of 14
your connection looks ok with the correct profile for your speed and a throughput of 13945
with a 16000kbps profile and a throughput at present of 13945kbps I would expect a download speed of 1750/2000kb/s
Newbie
Message 9 of 14
Really... I thought my download speed would near enough match my broadband speed.
Or am I being naive??
Message 10 of 14
Hi your download speed is relative to your ip profile which is always lower than your connection speed to allow for network operating overheads
