Tuppe28
Message 1 of 11
Speed drop since router upgrade
Hi,
Recently moved from O2/Sky to BT and changeover etc was smooth, which was good.
However since the HH4 upgrade on 22nd November the download speed has dropped by around 10%.
Before and after stats below and any advice appreciated.
Before router upgrade
18:01:57, 04 Nov.( 133.610000) DSL noise margin: 17.00 dB upstream, 6.10 dB downstream
18:01:57, 04 Nov.( 133.540000) DSL line rate: 448 Kbps upstream, 3328 Kbps downstream
After upgrade  (22nd Nov on)
04:24:40, 22 Nov.( 77.830000) DSL noise margin: 16.00 dB upstream, 6.20 dB downstream
04:24:40, 22 Nov.( 77.760000) DSL line rate: 448 Kbps upstream, 3040 Kbps downstream
10 REPLIES 10
Message 2 of 11
Re: Speed drop since router upgrade
most likely the cause of the low sync was the time of day the resync was done on the 22nd of November a restart is best tried around midday not in hours of darkness just try one restart and you should resync at a higher connection speed and given 3/5 days your IP profile will then rise also
Tuppe28
Message 3 of 11
Thanks for the advice.
Have reset and will see how it goes.
Message 4 of 11
please repost the noise margin and connection figures so we can compare them after the restart
Tuppe28
Message 5 of 11
Hi
After restart below
10:39:53, 08 Dec.( 86.870000) DSL noise margin: 17.00 dB upstream, 6.20 dB downstream
10:39:53, 08 Dec.
( 86.680000) DSL line rate: 448 Kbps upstream, 2976 Kbps downstream
But just had a dropout and downstream dropped significantly!
21:17:51, 10 Dec.(30993.410000) DSL noise margin: 17.00 dB upstream, 5.20 dB downstream
21:17:51, 10 Dec.(30993.340000) DSL line rate: 448 Kbps upstream, 1216 Kbps downstream
Wondering if I should restart again....
It's pretty frustrating as was previously with O2 and stable 3 down for years!
Cheers
Message 6 of 11
try one reset around midday tommorow when the noise margin is at its best
Tuppe28
Message 7 of 11
Will do.
Tuppe28
Message 8 of 11
Hi,
Reset again and connection has been stable since, but still over 10% less
12:13:50, 11 Dec.( 87.460000) DSL noise margin: 18.00 dB upstream, 6.00 dB downstream
12:13:50, 11 Dec.( 87.290000) DSL line rate: 448 Kbps upstream, 2688 Kbps downstream
Message 9 of 11
there is little chance of any further speed increase due to you already being on the default noise margin
Tuppe28
Message 10 of 11
Thanks for reply
Don't understand the speed drop though as have had a solid 3M on O2 for years.
Going from 3328 Kbps downstream to 2688 Kbps downstream for no apparent reason isn't a good start with a new provider.
