Keith_Beddoe
Message 11 of 26
Re: Speed drop
@m0nster wrote:
For the last week or so my braodband has slowed right down. I have restarted the router and this fixes the problem until the next day when it decides to slow down again.
Is this only happening on a wireless connection, or is it the same if you use a direct Ethernet cable?
m0nster
Message 12 of 26
Re: Speed drop
It's the same for the PC that's connected to ethernet.
ray_dorset
Distinguished Guru
Message 13 of 26
Re: Speed drop
Is it slow right now? try this next time it slows down:
In order to rule out the Homehub as potentially being the device responsible for your speed loss, you can connect the Openreach modem directly to the PC and see if the speed improves.
To do that follow these steps:
Step 1: Remove the homehub from the modem cable
Step2: Connect your pc/laptop to the modem via the cable instead
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username bthomehub@btbroadband.com and the password as BT
Step6: connect, If it doesn't, keep pressing try again until it does.
However, please note that this will stop any other access apart from the PC
If not, I'll try again 🙂
m0nster
Message 14 of 26
Re: Speed drop
I'll give that again next time. Thank you.
m0nster
Message 15 of 26
Re: Speed drop
Hey, I tried out what you mentioned before and it's still the same =\
ray_dorset
Distinguished Guru
Message 16 of 26
Re: Speed drop
Odd, because replacing the router with a PC is essentially the same as restarting the router.
pippincp
Sage
Message 17 of 26
Re: Speed drop
And also rules out the router as the problem.
m0nster
Message 18 of 26
Re: Speed drop
What happened was my speed dropped to a snail pace, so I restarted everything, plugged computer directly to modem and it was all fine until some time during the night my speed dropped as it has every other day =\
m0nster
Message 19 of 26
Re: Speed drop
Hi, just thought I'd give an up date on the situation.
Internet still cutting out during the day, sometimes twice and going down to ridiculous speeds that you can't even load a webpage. Still having to restart it to get the speed back up although that's getting lower and lower.
Any further help and input would be greatly appeciated.
m0nster
Message 20 of 26
Re: Speed drop
Just came home and my speed has dropped yet again. Here are it's current stats before I restart it again
1. Product name:BT Home Hub 3.0B
2. Serial number:+058721+113010AJKT
3. Firmware version:V100R001C01B036SP05_L_B. Last updated 11/11/13
4. Board version:VER.D
5. WAN:PPP Connected
6. Data sent/received:12292349/124837851 B
7. Broadband username:bthomehub@btbroadband.com
8. BT FON:Yes
9. Wireless network/SSID:BTHub3-GTG3
10. Wireless connections:Enabled (b/g/n, 20M, WPS Enabled)
11. Wireless security:WPA and WPA2
12. Wireless channel:Automatic/11
13. Firewall:Default
14. MAC Address:20:2B:C1:78:0C:20
15. Software variant:05_L_B
16. Boot loader:1.0.37-106.5
I think I'll just contact ISPA as last time I contacted them they got BT to pull their finger out and sort it out instead of going through the useless call centre.
