icepuffin
Message 1 of 39
Speed dropped below 1mb
goodmorning,
i have been with BT for a number of years and not had a problem with the service, so far.
We normally get around 7mb down speed but for the last two days it has dropped to about 1 mb and below taking ages to load a page. I have switched off my home hub4 and also my computers but it is still slow. I have checked my line and any faults in the area and there are none reported.
I know that sometimes it can be "tweaked" from BT end to improve the speed,
Not sure where I go from here?
38 REPLIES 38
icepuffin
Message 2 of 39
Re: Speed dropped below 1mb
I have tried to do a speed test but as I am on an iPad it will not let me. I have downloaded an app and that gives me a speed of 1.4mb
imjolly
Message 3 of 39
in order for the forum members to help please can you post the adsl stats from your router you may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or if HH4/5 then go to troubleshooting then logs and you are looking for 2 line together when hub last connected to internet and they will show your connection speed and noise margin or if netgear enter 192.168.0.1). Then run  btspeedtester  (MAC users may have problems). when first test completes then run diagnostic test and post the results ( do not reset the router).
enter your phone number and post results  remember to delete number https://www.btwholesale.com/includes/adsl/main.html
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
icepuffin
Message 4 of 39
Thank you for your reply. I think I have done what you have asked and hopefully I have been succesful in attaching it to this reply. when i went into troubleshooting  it came up with "all" which is what i copied.
i copied it to a word document but i am unable to find out how to download it to here. i tried link image and found the file on my computer but when i try and copy it to this reply it comes up with an error code, so now i'm stumped.
icepuffin
Message 5 of 39
will try and copy and paste here.
Event Log
This page summarises all the recent events that have been recorded on your BT Home Hub.
You can filter the events to show items related to a specific category.
Category
                click to change category dropdown
Recorded events
Time and date   Message
08:34:01, 06 Aug.              (68694.950000) Admin login successful by 192.168.1.112 on HTTP
08:32:47, 06 Aug.              (68620.520000) New GUI session from IP 192.168.1.112
08:29:51, 06 Aug.              OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.112]:54487-​>[66.235.139.18]:443 on ppp0)
08:24:58, 06 Aug.              (68152.030000) Device disconnected: Hostname: HPB82435 IP: 192.168.1.114 MAC: dc:4a:3e:b8:24:35
08:24:58, 06 Aug.              (68152.000000) Lease for IP 192.168.1.112 renewed by host LAPTOP-​LNF0P0DE (MAC e0:94:67:77:70:90). Lease duration: 1440 min
08:24:58, 06 Aug.              (68152.000000) Device connected: Hostname: LAPTOP-​LNF0P0DE IP: 192.168.1.112 MAC: e0:94:67:77:70:90 Lease time: 1440 min. Link rate: 72.2 Mbps
08:24:58, 06 Aug.              (68151.880000) Lease requested
08:24:58, 06 Aug.              (68151.570000) Lease for IP 192.168.1.112 renewed by host LAPTOP-​LNF0P0DE (MAC e0:94:67:77:70:90). Lease duration: 1440 min
08:24:58, 06 Aug.              (68151.570000) Device connected: Hostname: LAPTOP-​LNF0P0DE IP: 192.168.1.112 MAC: e0:94:67:77:70:90 Lease time: 1440 min. Link rate: 72.2 Mbps
08:24:58, 06 Aug.              (68151.450000) Lease requested
08:24:58, 06 Aug.              wlan0: STA e0:94:67:77:70:90 IEEE 802.11: Client associated
08:24:02, 06 Aug.              IN: BLOCK [16] Remote administration (TCP [94.102.49.174]:40194-​>[109.152.47.229]:8080 on ppp0)
08:11:44, 06 Aug.              IN: BLOCK [16] Remote administration (TCP [185.40.4.90]:49006-​>[109.152.47.229]:80 on ppp0)
icepuffin
Message 6 of 39
is this what you require?
icepuffin
Message 7 of 39
AS I have mentioned , not had an issue until last couple od days, have checked 'line' and it's all ok, have tried reboot with no success, could the hub be on the way out? as it's a few years old now?
imjolly
Message 8 of 39
if you can go back to troubeshooting then wan and you are looking for 2 likes like this
21:41:18, 26 Jul. ( 2123.010000) DSL noise margin: 6.00 dB upstream, 6.10 dB downstream
21:41:18, 26 Jul. ( 2122.900000) DSL line rate: 1215 Kbps upstream, 9398 Kbps downstream
are you using test socket?
did you try quiet line test
icepuffin
Message 9 of 39
13:30:27, 05 Aug.
( 101.770000) PPP IPCP Receive Configuration ACK
13:30:27, 05 Aug.
( 101.730000) PPP IPCP Send Configuration ACK
13:30:27, 05 Aug.
( 101.730000) PPP IPCP Receive Configuration Request
13:30:27, 05 Aug.
( 101.690000) PPP IPCP Send Configuration Request
13:30:27, 05 Aug.
( 101.680000) PPP IPCP Receive Configuration NAK
13:30:27, 05 Aug.
( 101.250000) PPP IPCP Send Configuration ACK
13:30:27, 05 Aug.
( 101.250000) PPP IPCP Receive Configuration Request
13:30:25, 05 Aug.
( 99.540000) PPP IPCP Send Configuration Request
13:30:25, 05 Aug.
( 99.540000) WAN operating mode is DSL
13:30:25, 05 Aug.
( 99.540000) Last WAN operating mode was DSL
13:30:24, 05 Aug.
( 98.140000) PPPoA is up -​ VPI: 0, VCI:38
13:30:24, 05 Aug.
( 98.130000) CHAP authentication successful
13:30:22, 05 Aug.
( 96.990000) CHAP Receive Challenge
13:30:20, 05 Aug.
( 95.000000) Starting CHAP authentication with peer
13:30:20, 05 Aug.
( 95.000000) PPP LCP Send Configuration ACK
13:30:20, 05 Aug.
( 95.000000) PPP LCP Receive Configuration Request
13:30:17, 05 Aug.
( 91.830000) PPP LCP Receive Configuration ACK
13:30:17, 05 Aug.
( 91.820000) PPP LCP Send Configuration Request
13:30:17, 05 Aug.
( 91.820000) PPP LCP Receive Configuration Reject
13:30:15, 05 Aug.
( 89.790000) PPP LCP Send Configuration Request
13:30:11, 05 Aug.
( 85.150000) ETHoA is up -​ VPI: 0, VCI:35
13:30:11, 05 Aug.
( 85.150000) DSL is up
13:30:10, 05 Aug.
( 84.130000) DSL noise margin: 6.00 dB upstream, 6.00 dB downstream
13:30:08, 05 Aug.
( 82.440000) DSL line rate: 1131 Kbps upstream, 5696 Kbps downstream
13:29:31, 05 Aug.
( 45.900000) WAN Auto-​sensing running.
13:28:41, 05 Aug.
(18329.460000) PPP LCP Send Termination Request [User request]
08:24:33, 05 Aug.
( 101.710000) PPP IPCP Receive Configuration ACK
08:24:33, 05 Aug.
( 101.710000) PPP IPCP Send Configuration ACK
08:24:33, 05 Aug.
( 101.710000) PPP IPCP Receive Configuration Request
08:24:33, 05 Aug.
( 101.710000) PPP IPCP Send Configuration Request
08:24:33, 05 Aug.
( 101.700000) PPP IPCP Receive Configuration NAK
08:24:33, 05 Aug.
( 101.310000) PPP IPCP Send Configuration ACK
08:24:33, 05 Aug.
( 101.310000) PPP IPCP Receive Configuration Request
08:24:31, 05 Aug.
( 99.670000) PPP IPCP Send Configuration Request
08:24:31, 05 Aug.
( 99.670000) WAN operating mode is DSL
08:24:31, 05 Aug.
( 99.660000) Last WAN operating mode was DSL
08:24:30, 05 Aug.
( 98.250000) PPPoA is up -​ VPI: 0, VCI:38
08:24:29, 05 Aug.
( 98.230000) CHAP authentication successful
08:24:29, 05 Aug.
( 98.120000) CHAP Receive Challenge
08:24:29, 05 Aug.
( 98.110000) Starting CHAP authentication with peer
08:24:29, 05 Aug.
( 98.110000) PPP LCP Send Configuration ACK
08:24:29, 05 Aug.
( 98.110000) PPP LCP Receive Configuration Request
08:24:28, 05 Aug.
( 96.470000) PPP LCP Receive Configuration ACK
08:24:27, 05 Aug.
( 95.370000) PPP LCP Send Configuration Request
08:24:27, 05 Aug.
( 95.370000) PPP LCP Receive Configuration Reject
08:24:23, 05 Aug.
( 92.090000) PPP LCP Send Configuration Request
08:24:19, 05 Aug.
( 88.210000) PPP LCP Send Configuration Request
08:24:16, 05 Aug.
( 85.060000) ETHoA is up -​ VPI: 0, VCI:35
08:24:16, 05 Aug.
( 85.060000) DSL is up
08:24:15, 05 Aug.
( 84.050000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
08:24:15, 05 Aug.
( 83.240000) DSL line rate: 1115 Kbps upstream, 5727 Kbps downstream
08:23:38, 05 Aug.
( 46.910000) WAN Auto-​sensing running.
08:15:07, 05 Aug.
(41683.470000) DSL is down after 693 minutes uptime
08:15:07, 05 Aug.
(41683.470000) ETHoA is down after 693 minutes uptime
08:15:07, 05 Aug.
(41683.120000) PPPoA is down after 693 minutes uptime [Waiting for Underlying Connection (WAN DSL -​ Up)]
08:15:03, 05 Aug.
(41678.950000) PPP LCP Send Termination Request [User request]
20:41:45, 04 Aug.
( 102.200000) PPP IPCP Receive Configuration ACK
20:41:45, 04 Aug.
( 102.110000) PPP IPCP Send Configuration ACK
20:41:45, 04 Aug.
( 102.110000) PPP IPCP Receive Configuration Request
20:41:45, 04 Aug.
( 101.920000) PPP IPCP Send Configuration Request
20:41:45, 04 Aug.
( 101.910000) PPP IPCP Receive Configuration NAK
20:41:44, 04 Aug.
( 101.420000) PPP IPCP Send Configuration ACK
20:41:44, 04 Aug.
( 101.420000) PPP IPCP Receive Configuration Request
20:41:42, 04 Aug.
( 98.710000) PPP IPCP Send Configuration Request
20:41:42, 04 Aug.
( 98.710000) WAN operating mode is DSL
20:41:42, 04 Aug.
( 98.710000) Last WAN operating mode was DSL
20:41:40, 04 Aug.
( 97.320000) PPPoA is up -​ VPI: 0, VCI:38
20:41:40, 04 Aug.
( 97.310000) CHAP authentication successful
20:41:40, 04 Aug.
( 97.100000) CHAP Receive Challenge
20:41:40, 04 Aug.
( 97.010000) CHAP Receive Challenge
20:41:39, 04 Aug.
( 95.840000) Starting CHAP authentication with peer
20:41:39, 04 Aug.
( 95.840000) PPP LCP Receive Configuration ACK
20:41:36, 04 Aug.
( 93.410000) PPP LCP Send Configuration ACK
20:41:36, 04 Aug.
( 93.410000) PPP LCP Receive Configuration Request
20:41:35, 04 Aug.
( 91.530000) PPP LCP Send Configuration Request
20:41:35, 04 Aug.
( 91.530000) PPP LCP Receive Configuration Reject
20:41:31, 04 Aug.
( 88.300000) PPP LCP Send Configuration Request
20:41:28, 04 Aug.
( 84.520000) ETHoA is up -​ VPI: 0, VCI:35
20:41:28, 04 Aug.
( 84.520000) DSL is up
20:41:27, 04 Aug.
( 83.540000) DSL noise margin: 5.90 dB upstream, 6.00 dB downstream
20:41:26, 04 Aug.
( 82.720000) DSL line rate: 1143 Kbps upstream, 5824 Kbps downstream
20:40:49, 04 Aug.
( 45.750000) WAN Auto-​sensing running.
17:24:43, 04 Aug.
( 155.080000) PPP IPCP Receive Configuration ACK
17:24:42, 04 Aug.
( 154.850000) PPP IPCP Send Configuration ACK
17:24:42, 04 Aug.
( 154.850000) PPP IPCP Receive Configuration Request
17:24:42, 04 Aug.
( 154.720000) PPP IPCP Send Configuration Request
17:24:42, 04 Aug.
( 154.720000) PPP IPCP Receive Configuration NAK
17:24:42, 04 Aug.
( 154.250000) PPP IPCP Send Configuration ACK
17:24:42, 04 Aug.
( 154.250000) PPP IPCP Receive Configuration Request
17:24:39, 04 Aug.
( 151.340000) PPP IPCP Send Configuration Request
17:24:39, 04 Aug.
( 151.340000) WAN operating mode is DSL
17:24:39, 04 Aug.
( 151.340000) Last WAN operating mode was DSL
17:24:37, 04 Aug.
( 149.930000) PPPoA is up -​ VPI: 0, VCI:38
icepuffin
Message 10 of 39
have completed a quiet line test, no noise.
next will try and find test socket
