imjolly
Message 21 of 39
Re: Speed dropped below 1mb
Have you tried changing the wireless channel.
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
inssider3.1.2.1
icepuffin
Message 22 of 39
if i switch the router off and then back on will that be the same as changing channel?
john46
Message 23 of 39
no that will not do it you need to change the channel manually
imjolly
Message 24 of 39
That will probably give you a different IP address but does nothing to your wireless connection
icepuffin
Message 25 of 39
tried to down load inssider, first time said it would take 9 minutes but timed out , second time said it would be 4 hours, so not been able to download yet.
icepuffin
Message 26 of 39
managed to use an ethernet cable, tried to run a speed test. came back with 'problem with speed test will run test again' then came back with 'something went wrong with speed test ' and that was that. ( i had switched off the ipad  so only one computer running.
I've tried everything I can think of now, is it possible that someone from BT please do a line and router test from thier side to try and bottom out the problem.
Thank you.
imjolly
Message 27 of 39
if you are having problem with inssider then try a wireless analyser on your ipad which will show wireless channels in use then select the least populated for your hub
icepuffin
Message 28 of 39
finally managed to download inssider.
I dont understand most of the programme, but it appears 3 of us on a BT network are using channel11. however according to the stats no co channeling and no overlapping. also my link score is 100 which i think is very good.
my signal is -50dbm ( whatever this means)
I have tried as suggested changing channel to both 1 and 6 but both these indicated co-channeling and overlapping.
imjolly
Message 29 of 39
Have you tried channel 13 as usually least used
icepuffin
Message 30 of 39
It didn't like me changing to channel 13 , it said that 12 and 13 might not be available ( or something similar) but it did change the link score dropped to 55 and channel changed to 40-44.
