cobhc
Message 1 of 17
Speed dropped
Hey guys,
I had been wondering why my connection seemed slightly slower than usual lately, and I've just checked and realized I'm connecting at a lower rate that usual. I've been connected at 7125 for at least 4-5 years now, and I'm not sure when the problem started but now I'm connecting at 6240.
Nothing in my setup has changed, so I'm not sure why this is happening.
Any ideas?
16 REPLIES 16
Message 2 of 17
Re: Speed dropped
Can you enter 192.168.1.254 into your browser then enter hub manager and post the adsl stats. Can you run btspeedtester and when first test completes then run diagnostic test
Are you connected to test socket?
http://speedtest.btwholesale.com
cobhc
Message 3 of 17
Re: Speed dropped
I'm not using a HH modem, but here are the stats from the TP-Link TP-8817 I'm using.
        Downstream    Upstream
SNR Margin
    12.5     21.0    db
Line Attenuation
    22.0     14.0     db
Data Rate
    6240     448     kbps
Max Rate
    5536     1024     kbps
POWER
    20.0     12.0     dbm
CRC
    0    0
Speedtest Diagnostic
1. Best Effort Test: -provides background information.
    Download  Speed
    5.25 Mbps
0 Mbps    7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 5.25 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :6.24 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 5.5 Mbps
Message 4 of 17
Re: Speed dropped
If you could get your 12db noise margin down to normal 6db or thereabouts then that would bring your connection speed back to expected
With your attenuation i would expect a connection speed of 8mb and profile of 7.15mb
Is there anything in stats that shows connection time?
cobhc
Message 5 of 17
Re: Speed dropped
Yeah, I thought that was a little high. The connection time would be useless as I just unplugged everything and plugged it back in again, guess I'll see how it goes over the next few days.
Message 6 of 17
Re: Speed dropped
If you can get to 3+ days connection time then repost your router stats again showing the connection time and then maybe get mods to reset your noise margin back to normal with your speed increasing back to 8mb
cobhc
Message 7 of 17
Re: Speed dropped
My TP-Link Router doesn't show connection time, maybe because I'm using it in bridged mode with an Asus RT-AC66U doing the PPPOE authentication?
Message 8 of 17
Re: Speed dropped
Mods normally like to see 3+ days connection time to show connection stable before resetting the noise margin
cobhc
Message 9 of 17
Re: Speed dropped
Guess I'll have problems then as the router doesn't show connection time.
Message 10 of 17
Re: Speed dropped
When mods read these post they will contact you and reset noise margin to get your speed back. Afte you complete the email link it can take the mods 3/5 working days to contact you again by either email or phone
Adsl connection is normally pppoa
