Message 1 of 17
Speed dropping down
Hi
I have a problem with my broadband long time ago speed was fine about 8mb last maybe 2 months drop down to about 2.2mb what is really annoying even cant watch youtube. I'm did all things to sorted this problem. Check microfilter, used test socked, changed cables, reset homehub to defaults and nothing help. Downloading is really slow and sometimes homehub lost connection for 5 maybe 10 min broadband icon blinking on orange (i have home hub 2.0)
If someone can help me please do this.
P.s. Sorry for bad English:)
Just add some statistic:
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download  Speed
1690 Kbps
0 Kbps
2000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 1690 Kbps
 For your connection, the acceptable range of speeds is 800-2000 Kbps.
 Additional Information:
 Your DSL Connection Rate :2100 Kbps(DOWN-STREAM), 120 Kbps(UP-STREAM)
 IP Profile for your line is - 1852 Kbps
2. Upstream Test:  -provides background information.
Upload Speed
94 Kbps
0 Kbps
120 Kbps
>Upload speed achieved during the test was - 94 Kbps
 Upstream Rate IP profile on your line is - 120 Kbps
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 1:34:31
Downstream2,101 Kbps
Upstream120 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)3.6 dB / 2.0 dB
Line attenuation (Down/Up)38.5 dB / 34.1 dB
Output power (Down/Up)0.0 dBm / 12.0 dBm
ADSL line status
Line stateConnected
Connection time0 days, 1:49:15
Upstream120 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.6 dB / 1.9 dB
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)2094629 / 0
CRC Errors (Down/Up)9 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)9804
16 REPLIES 16
Recognised Expert
Message 2 of 17
Re: Speed dropping down
Im jsut gonna direct you to the mods http://bt.custhelp.com/app/contact_email/c/4951 in this case, something is really just not right there, with a connection that slow on an SNR margin that low, and attenuation, its just not not not not .... right!.
Message 3 of 17
when you used the test socket did you leave it connected there for a few days?  I would suggest in the first instance it to connect to the test socket again as that is your direct connection to the exchange
Message 4 of 17
ok i will do that. use test socket for few days then i posted results. thanks for info.
Message 5 of 17
can I suggest you post your stats after you connect to test socket and then again in a day or so and that will give figures to compare and see it made any difference
Message 6 of 17
ok this is speedtest on test socked:
 Download  Speed
 1999 Kbps
0 Kbps2000 Kbps
 Download speedachieved during the test was - 1999 Kbps
 Your DSL Connection Rate :2487 Kbps(DOWN-STREAM), 100 Kbps(UP-STREAM)
 IP Profile for your line is - 2193 Kbps
 Upload Speed
 49 Kbps
0 Kbps100 Kbps
>Upload speed achieved during the test was - 49 Kbps
 Upstream Rate IP profile on your line is - 100 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
ADSL line status
Line stateConnected
Connection time0 days, 1:05:56
Downstream2,487 Kbps
Upstream100 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.3
Noise margin (Down/Up)3.4 dB / 3.1 dB
Line attenuation (Down/Up)35.5 dB / 34.4 dB
0.0 dBm / 11.4 dBm
ADSL line status
Line stateConnected
Connection time0 days, 1:06:12
Upstream100 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Output power (Down/Up)0.0 dBm / 11.4 dBm
FEC Errors (Down/Up)0 / 4294967263
CRC Errors (Down/Up)6339 / N/A
Error Seconds (Local)8
Message 7 of 17
Ok now leave the hub connected to the test socket and check the hub stats again in 24 hours and post back the results please
Message 8 of 17
ok this is another test after one day on test socket.
 Download  Speed
 1975 Kbps
0 Kbps2000 Kbps
 Download speedachieved during the test was - 1975 Kbps
 Upload Speed
 69 Kbps
0 Kbps100 Kbps
>Upload speed achieved during the test was - 69 Kbps
ADSL line status
Line stateConnected
Connection time0 days, 22:43:15
Upstream100 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.8 dB / 3.2 dB
ADSL line status
Line stateConnected
Connection time0 days, 22:43:42
Upstream100 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)3.8 dB / 2.4 dB
CRC Errors (Down/Up)39937 / N/A
Error Seconds (Local)10
Message 9 of 17
still not right so I suggest you contact the mods  http://bt.custhelp.com/app/contact_email/c/4951
Message 10 of 17
Hi The mods normally reply by email or phone directly to you within 72 hours
They are a UK based specialist team who have a good record at getting problems solved
