Message 1 of 12
Speed drops and line noise
Hi all
Having a few issues with my adsl2+ in the last week or so, So far i have done multiple tests, removed the extentions from the master to rule out any internal faults, checked all terminations and even removed and punched down wiring
changed the master to rule that out (v1.0 to a NTE5c), Checked and done resistance and capacitance  tests from the incomming drop to the master
i have traced the fault down as far as i can, The symptoms are, the line has a hiss and you can here the adsl with the router connected disconnect the router the line clears, reconnect the router and you can here it handshake and the hiss returns, on a quite line test the line intermetantly clears but as soon as you clear down the noise is back
Before the issue i got 12-15mb down and around 1-2mb up now my ip profile has dropped it to 8mb down and 0.37 up - my ping has dropped through the floor it was 6-8ms now its 18-100ms depending on the server making game play next to impossible
I have ruled out the router as i have the same issues with the 4 routers i have tested (known good - HH4, Draytek 2830, Known good - Netgear DG834 v4 and a brand new adsl/vdsl Draytek 2860ac)
Here's a snapshot of the draytek (telnet)
11 REPLIES 11
Expert
Message 2 of 12
Re: Speed drops and line noise
I think you have answered your own question, get the noisy line fixed and your speed should improve.
Message 3 of 12
All of bt's test come back clear - phoning india is like banging your head against a brick wall as there reading from a script, i am reluctant to book an engineers visit as it could be £130
It seems like a high resistace fault, thinking about it it could be releated to the storm we had as its mainly overhead copper around here
Message 4 of 12
well my upload speed has gone to 34000 bps good one bt
Message 5 of 12
I bit the bullet and booked a engineer for monday, fingers crossed its a simple fix
Message 6 of 12
if you want to avoid the charge then you need to check the line noise is at the test socket if it is there is no charge
Message 7 of 12
There is line noise as soon as the router handshakes as above i have test everything as you can see above the speeds are slow upload speeds are 70% and downloads are 50% of what they where and the line att is over double, tested at the faceplate with no extentions connected - same fault
I dont use poor/cheap equipment my draytek router has been working flawlessly for many years but i did test with other equipment that are know good
bt failed to book the appointment with openreach correctly so i have wasted a day, confirmed with bt/openreach for another appointment Cat Mad
Message 8 of 12
Just to add no extentions are connected to the master there is line noise as soon as the asdl handshakes, make a phone call it drops the adsl - router reconnects then the hiss and the the adsl handshaking can be heard
Message 9 of 12
Well another cancelled appointment 'due to it not being booked correctly' re-booked again funny thing is the indian lady couldnt hear me due to line noise
Message 10 of 12
That would tend to indicate a missing microfilter, how is your phone connected?
Which one of these matches your master phone socket?
If you have the first one then
Please connect things up as shown below, and see if the noise on the phone stops.
Remember, you will be charged if you have not connected things up correctly.
