cjcrawshaw
Message 1 of 8
Speed drops off on broadband
Hi,
About 2 months ago I upgraded from ADSLMax to ADSL2+ and have since added BT Vision. I have had the home hub for around 14 months if that makes any difference.
I've noticed when trying to stream video that I get a lot of buffering. This happens when using the computer (wired connection) or through the BT vision box, to the point where it is impossible to stream videos.
If I restart the router, the connection is great for around half an hour then drops.
I've done the test from http://www.speedtester.bt.com/ and have posted that and the router details below.
Any help would be greatly appreciated!
Cheers,
Chris
Download speedachieved during the test was - 5.85 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 18.65 Mbps
Connection Information
Line state:Connected
Connection time:0 days, 00:55:12
Downstream:20.65 Mbps
Upstream:1.137 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):2.7 dB / 6.7 dB
Line attenuation (Down/Up):3.4 dB / 2.1 dB
Output power (Down/Up):17.8 dBm / 10.1 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):152448 / 42
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):122520 / 7
Error Seconds (Local/Remote):3312 / 0
7 REPLIES 7
Message 2 of 8
Re: Speed drops off on broadband
your noise margin is low and on some lines this causes a problem and like your there are a lot of crc/hec errors.  this will restrict your download speed  check here first this was done by keith to help
noise margin
cjcrawshaw
Message 3 of 8
Many thanks, interesting article. The latest reboot seems to have helped so hopefully I have a more stable frequency. The speed has dropped to 20.18 on the hub backing this up. If it continues I will try disconnecting the adsl line rather than rebooting the router.
Many thanks,
Chris
Message 4 of 8
the unfortunate thing is it will only last for a short period as it will drop again when the exchange sees your stable connection.  the longer term solution is to get mods to set your noise margin to 6db but can try that later - just see how it goes
cjcrawshaw
Message 5 of 8
Thanks again. Still no joy though. Still dropping and the latest speed test, before and after adsl line reconnects, seems to hover at just under 2 Mbps. On to the MODs then.
Cheers,
Chris
Message 6 of 8
this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
cjcrawshaw
Message 7 of 8
Many thanks again, was just looking for that and couldn't find it!
Request sent to the MODs for this.
Understood regarding the time. I have contacted the MODs before about switching to ADSL2+ and were very helpful, albeit they must be swamped under!
Cheers,
Chris
Message 8 of 8
keep us updated please
