richard1athome
Message 1 of 53
Speed drops since firmware SG4B1000B316
I have also had significant speed drops since the update. My line can only get 20mbps as a max and previous to the update I was gettinga solid 10-15..which is fine for me but since the update the speed has been completely erratic..sometimes 17mbps...but more often below 2mbps...countless calls in to BT. Engineer recabled between exchange and cabinet which held for 24hours...then was told it might be a network issue which apparently was fixed..still cannot hold a connection. Getting nowhere fast with BT i'm afraid despite raising a complaint. Factory reset smart hub twice.
52 REPLIES 52
Webby
Message 2 of 53
Re: Speed drops since firmware SG4B1000B316
Try a third party router
JohnC2
Moderator
Moderator
Message 3 of 53
Hi @richard1athome Welcome to the forum and I moved your post to create your own thread as that's the best thing to do.
Sorry you are experiencing a drop in your connection speed. Have you checked your line 17070 to ensure that there is no noise interference on the line.
Also will you post the stats from your Smart Hub, (Homehub 6) can you go to hub manager then advanced then technical log and post the stats. http://bthomehub.home/
cheers
John
richard1athome
Message 4 of 53
Hi....yes i did a quiet line test and that was fine.
under the tech log - is it the event log that needs posting?
john46
Message 5 of 53
no the helpdesk /information page are the one needed
richard1athome
Message 6 of 53
sorry John and which category if its the event log?
john46
Message 7 of 53
post the information page details
richard1athome
Message 8 of 53
Product name:
BT Hub 6A
Serial number:
+084319+NQ62108089
Firmware version:
SG4B1000B316
Firmware updated:
28-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 48 Minutes 43 Seconds
Data rate:
1.22 Mbps / 23.43 Mbps
Maximum data rate:
1221 / 24141
Noise margin:
6.2 dB / 5.3 dB
Line attenuation:
30.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
399 MB Uploaded / 48 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
WilliamsHUB
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
WilliamsHUB
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:4D:4A:17:19:37
Software variant:
Boot loader:
7.33.1
richard1athome
Message 9 of 53
BT wholesale performance fluctuates wildly from my end but BT often say is solid and stable their end
richard1athome
Message 10 of 53
Hi John....just had another call from BT and once again they think it might be a network issue (was told that before and it was meant to have been resolved)..I despair
