richard1athome
Message 31 of 53
Re: Speed drops since firmware SG4B1000B316
Hi David. Well all was fine until 3:30 today when the connection speed fell back to below 1 Mbps. No problems reported in the area. Rebooted hub..no change. Anything else we can do now?
DavidM
Moderator
Moderator
Message 32 of 53
Hi @richard1athome,
Thanks for posting. Sorry the connection has dropped again. Can you run the speed test on a wired connection including the further diagnostics and post the results?
Cheers
David
richard1athome
Message 33 of 53
HI - Basically got the 'We’re sorry, something went wrong.' screen after attempting the wired speed test. but below is the Hub data. Product name: BT Hub 6A Serial number: +084319+NQ62108089
Firmware version: SG4B1000B316
Firmware updated: 28-Jul-2017
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 1 Hours 15 Minutes 48 Seconds
Data rate: 1.21 Mbps / 23.48 Mbps
Maximum data rate: 1205 / 24334
Noise margin: 6.7 dB / 5.4 dB
Line attenuation: 30.2 dB
Signal attenuation: VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 605 MB Uploaded / 161 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Not active 2.4 GHz wireless network name: WilliamsHUB 2.4 GHz wireless channel: Smart (Channel 1) 5 GHz wireless network name: WilliamsHUB 5 GHz wireless channel: Smart (Channel 36) Wireless security: WPA2 (Recommended) Wireless mode: Mode 1 Firewall: On MAC address: 90:4D:4A:17:19:37 Software variant: - Boot loader: 7.33.1
richard1athome
Message 34 of 53
Apologies David...I didnt do the wholesale test just a normal wired speed test. here are the wholesale results.
Download speedachieved during the test was - 2.56 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-21.34 Mbps .
Additional Information:
IP Profile for your line is - 21.34 Mbps
DavidM
Moderator
Moderator
Message 35 of 53
Thanks for posting the test reults @richard1athome.
They confrm you're connection and around 23meg. I've also tested this with wholesale and the results confirm its currently 22meg.
Cheers
David
DavidM
Moderator
Moderator
Message 36 of 53
Thanks again @richard1athome. It looks like there is a problem based on your test results. Leave it with me and I'll be in touch.
Cheers
David
richard1athome
Message 37 of 53
but the wholesale test i just did showed 2.56.....this is pretty much the same issue Ive been getting for 7 weeks or so....
richard1athome
Message 38 of 53
both my attempt to do a bt speed test and wholesale show there is still something wrong somewhere.
richard1athome
Message 39 of 53
sorry...its so slow we keep missing each other.
DavidM
Moderator
Moderator
Message 40 of 53
No problem @richard1athome. Leave it with me for now.
Cheers
David
