montesansavino
Message 1 of 17
Speed from 5 down to 3.8
I used to get nearly 5 meg on this copper line. Now it is 3.8
It would be great to get back to over 4.5 but BT Retail say it is within the speed for this lineso don't do anything. Not helpful really.
16 REPLIES 16
jac_95
Guru
Guru
Message 2 of 17
Re: Speed from 5 down to 3.8
Hi montesansavino,
Sorry to hear that your  having issues with your BT Retail services.
You will either be on the ADSLMax (upto 8mbps) service or if your exchange has been BTw 21cn upgraded you maybe on the ADSL2/2+ (upto 12/20mbps) service depending on your line quality and length.
However these upto speeds may not be the speeds you will get as ADSL broadband connections are very dependent on the distance from your property to the exchange and the quality of your line. The further away you are from your local exchange the slower your broadband speed will be.
To enable the community to help you please see the advice below:
Please see Keith's help guide here: Helping forum members to help you, it will go through some checks that are needed for us to help you.
A summary of the checks are:
1a) Is your router/Homehub connected by a BT NTE5 master socket, Adsl Filtered Master Socket or Extension Socket?   Please bear in mind that extension cables and extension sockets can reduce the broadband's performance. If you have an Old LJU master socket then please say.
1b) Have you tried the Test Socket? - if you have one.
2) Can you please run a BT speed test (including IP Profile) http://speedtest.btwholesale.com (not beta version)[Best done with a wired, Ethernet, connection] After Quick Test is done you need to click "Further Diagnostics" to get IP Profile.
3) is there any noise on your line. dial 17070 option2 ,called quite line test, from landline phone. should be silent but slight hum normal on cordless phone.
4) please post adsl line statistics
ADSL Line Statistic Help:
 If you have a BT Home Hub like the one below...
 Then:
 1) Go to http://192.168.1.254 or http://bthomehub.home
 2) click Settings
 3) Click Advanced Settings
 4) Click Broadband
 5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3.A firmware ending in 1.3)
or http://bthomehub.home/index.cgi?active_page=9118 (for bthomehub3.A firmware ending in 94.1.11)
You will need to copy and past all the adsl line statistics ( Including HEC, CRC and FEC errors). You may need to click " More Details"
 If you have a HomeHub 4 then the majority of the ADSL Stats shown in the previous Hubs will not be there.
for HH4 users you can go to hub manager then select troubleshooting then logs and are look for 2 entries together which will show theconnection speed and noise margin for when your HH4 last sycned with the exchange.
There are more useful links on Keith's website here: If you have an ADSL connection, please select this link
Don't have a BT Homehub/Voyager?
 http://192.168.0.1 for a netgear router and look for ADSL adsl statistics with information like noise margin and line attenuation, connection speed
• http://192.168.2.1 for a belkin router and look for ADSL adsl statistics with information like noise margin and line attenuation, Data Rate
 cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
jac_95
Guru
Guru
Message 3 of 17
@montesansavino,
Also have a look at this article in Keith_Beddoe's personal website about why your broadband speed may have dropped: Why has my speed dropped
Cheers
Try a Search
montesansavino
Message 4 of 17
i will give it a go, thank you
montesansavino
Message 5 of 17
IP profile is 4.01 up and 0.83 down. The info on the hub is:
ADSL Line Status
Connection information
Line state:Connected
Connection time:0 day, 00:20:43
Downstream:4,544 Kbps
Upstream:824 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):13.3 dB / 6.5 dB
Line attenuation (Down/Up):49.0 dB / 27.9 dB
Output power (Down/Up):0.0 dBm / 12.9 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):30 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):139 / 0
Error Seconds (Local/Remote):0 / 0
john46
Message 6 of 17
providing you can maintain a stable connection for the next 3/5 days then the forum mods can get involved and reset your noise margin which will improve your connection speed and also your download speed
imjolly
Message 7 of 17
your connection time is only 20min is that due to router dropping conenction or manual reset?
montesansavino
Message 8 of 17
There has been no change. Here are the details for the past 4 days. I would love to get back to 4.5
ADSL Line Status
Connection time:4 days, 15:05:29
Upstream:839 Kbps
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Latency type:Fast
Noise margin (Down/Up):11.6 dB / 7.0 dB
Line attenuation (Down/Up):49.0 dB / 27.8 dB
CRC Events (Down/Up):284399 / 5
HEC Errors (Down/Up):555944 / 6
0 / 4
imjolly
Message 9 of 17
Once the mods read your post they will post a link for you to contact them
RobbieMac
Moderator
Moderator
Message 10 of 17
Hi montesansavino,
Thanks for posting and welcome to the community!
I can help give your connection speed a "nudge" in the right direction Smiley Happy
Click on my username and under the section "about me" you'll see the link to get in touch with us.  Whenever we've received your details we'll take it from there.
All the best,
Robbie
