montesansavino
Message 11 of 17
Re: Speed from 5 down to 3.8
Thank you. I have done that.
john46
Message 12 of 17
The forum mods normally reply to you personally within 3/5 working days by either  email or phone
imjolly
Message 13 of 17
please repost your stats after mods reset your noise margin to show the improvement - good for forum
montesansavino
Message 14 of 17
I'll do so
montesansavino
Message 15 of 17
It worked as of 21st October
downlaod 5.9 (7.5 max) and upload 0.72 (0.83 max)
connection details:
ADSL Line Status
Connection information
Line state:Connected
Connection time:1 day, 00:48:53
Downstream:6,595 Kbps
Upstream:847 Kbps
This is as good as it going to get. Thank you for the help.
  ADSL settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Fast
Noise margin (Down/Up):5.1 dB / 6.3 dB
Line attenuation (Down/Up):48.5 dB / 27.8 dB
Output power (Down/Up):0.0 dBm / 12.8 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):206398 / 43
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
HEC Errors (Down/Up):276819 / 54
Error Seconds (Local/Remote):0 / 26
imjolly
Message 16 of 17
connection speed looks ok and probably as good as you can get and noise margin now about normal 6db  you are on fast and getting quite a few crc/hec errors so I would watch in case the start to escalate and cause a problem with pages loading at night
john46
Message 17 of 17
interleaving should come on automatically if the errors climb to high
