Message 11 of 21
Re: Speed halved since..
You could have an external line fault which is is picking up interference, or perhaps a high resistance connection.
Can you please run a line test and see if it shows a fault condition.
You can do it from here.
Reporting Phone Faults
Lime21
Message 12 of 21
Lime21
Message 13 of 21
Message 14 of 21
I assume that you are using BT as a phone service provider?
Message 15 of 21
FON has no effect on your connection speed as Keith has already posted
The problem is most likely a line fault
Lime21
Message 16 of 21
Lime21
Message 17 of 21
Lime21
Message 18 of 21
Message 19 of 21
@Lime21 wrote:
i have tryed the line test twice now and all that happens is my broadband drops for 2 mins then comes back..
That is correct it will disconect while the test takes place
Also using FON has no effect on getting Infinity that depends on if your local street cabinet is upgraded from your post it sound as though you are on a different cabinet to those on the other side of the road which is quite common
Lime21
Message 20 of 21
Thanks anyway, i'll continue to be a frustrated BT customer like hundreds of others.
