So the Openreach broadband engineer called in on Weds, line checks were fine over the full spectrum in both directions. Possibly an issue with the modem so that has been swapped out.
Upon reconnection exactly the same speeds.. odd? No evidence of DLM sensing the interruptions.......
So, I thought time to try a little test to see if I could shake the connection up a little and ran rapid resets and disconnects for approx an hour. No change, an instant reconnect at the same speeds.....
OK, thought I, lets try disconnecting overnight, next day an immediate reconnect at the same speed......
Is it possible that DLM has been switched off on my connection and I am on a fixed line speed? (This would explain why the connection cannot retrain to a higher speed)
There you go John, the latest hub stats and strangely enough as I did sort of mention above nothing much has altered........
ADSL Line Status
Line state: | Connected |
Connection time: | 0 day, 02:56:30 |
Downstream: | 13,359 Kbps |
Upstream: | 736 Kbps |
VPI/VCI: | 0/38 |
Type: | PPPoA |
Modulation: | G.992.5 Annex A |
Latency type: | Fast |
Noise margin (Down/Up): | 6.1 dB / 5.7 dB |
Line attenuation (Down/Up): | 22.5 dB / 10.3 dB |
Output power (Down/Up): | 20.7 dBm / 11.9 dBm |
FEC Events (Down/Up): | 0 / 0 |
CRC Events (Down/Up): | 73 / 366 |
Loss of Framing (Local/Remote): | 0 / 0 |
Loss of Signal (Local/Remote): | 0 / 0 |
Loss of Power (Local/Remote): | 0 / 0 |
Loss of Link (Remote): | 0 |
HEC Errors (Down/Up): | 57 / 238 |
Error Seconds (Local/Remote): | 0 / 247 |
BTW no insult intended John and I am sure you mean well but your responses seem to add little to the discussion other than a set of preformatted statements, failing to address the specific points I reference in my posts.
BTW the BT wholesale speed test still gives the same line profile too.
So how does that explain the issue that the DLM is not modifying my connection speed for instability and my connection speed has remained pretty much constant over the duration of the connection even including the 10 day training period?
Also I would call the statement that my upload is normal for ADSL2+ as plain rubbish or misdirection, how do you explain the varying rates of connection by line length etc? Others with similar attenuation, noise margin are connecting at 1M+......
Re. The comment that my IP will be 88.2% of my connection does not explain me having a download speed of 12.4 on a 13.359 connection which equates to 93%?
Something is definitely not correct with my connection....
@Semmy wrote:So the Openreach broadband engineer called in on Weds, line checks were fine over the full spectrum in both directions. Possibly an issue with the modem so that has been swapped out.
That's actually quite a clever test you did .... and as you rightly state, it's almost as if the line is void of any line management. The fast and furious disconnects you undertook should by all accounts have sent the connection into line flap mode, or at least heightened downstream margin ... yet nothing.
You're right to ask the question about whether there is an issue, especially how the line is configured on the msan.
I would write in again, as the notes will be on file, and ask the moderators to request a network config check of the connection with Btw. (almost augurs of line clamping on the msan) .... allbeit a strange situation. 😉
Thanks for that Roger, that would make more sense!
Just had an email back from the mod team, apparently my MTBR is quite high (not sure what that is though) that may have a stabilising effect on the DLM. They have also checked my line speed isnt clamped, also BTw have confirmed this (would that be a records check, a software report or a physical check of the MSAN though?).
The next step I have requested (upon their suggestion) is a lowering of my noise margin to 3dB, this will either boot the DLM into activity or boost my speeds... Either one being a result TBH as I suspect they may not be able to "convince" the noise margin to move.
So, it's wait out again!
