purpse
Message 1 of 106
Speed jump
Hello. My router has just reconnected with a sync speed of 80mbps. It was previously 50 mbps. A quick speed test confirms around 72mbps. I havnt asked for an upgrade and I didnt reset my router. Im not complaining, but can anyone explain this?
Regards
105 REPLIES 105
Webby
Message 2 of 106
Re: Speed jump
Post up the stats from the router please.
Your line may have been banded or some connections may have been remade as part of a larger scale repair.
There could be many reasons to be honest.
XRaySpeX
Recognised Expert
Message 3 of 106
Re: Speed jump
Are only paying for Infinity 1 but are now getting Infinity 2 speeds?
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
DavidM
Moderator
Moderator
Message 4 of 106
Re: Speed jump
Hi @purpse and thanks for posting.
This does sound odd. If you haven't upgraded to Infinity 2 then you shouldn't be seeing those connection speeds. Are you able to post the information as requested by @XRaySpeX and @Webby?
Cheers
David
licquorice
Message 5 of 106
Re: Speed jump
I suspect there is a disappointed customer somewhere that was expecting a move from Infinity1 to Infinity2 that didn't happen! Smiley Wink
DavidM
Moderator
Moderator
Message 6 of 106
Re: Speed jump
You might have a point there @licquorice Smiley Wink
Cheers
David
purpse
Message 7 of 106
Re: Speed jump
Not sure if this is what your looking for but its all I could find:
DSL uptime:
0 Days, 5 Hours 31 Minutes 3 Seconds
Data rate:
18.79 Mbps / 80.00 Mbps
Maximum data rate:
18793 / 83750
Noise margin:
6.2 dB / 6.9 dB
Line attenuation:
19.4 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
125 MB Uploaded / 2214 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.
PheeragHfre
Recognised Expert
Message 8 of 106
Re: Speed jump
Make that at least TWO! 😞
"I have this awful feeling someone is watching every move I make (one of my pet hates is router location tagging)." Marvin (A paranoid Android)
Webby
Message 9 of 106
Re: Speed jump
@purpse
Are you on Infinity 1? What does it show in your online BT account? Any recent orders?
Perhaps you have been on Infinity 2 for a while but banded at a lower speed which has just been lifted?
ajh79
Message 10 of 106
Re: Speed jump
I have experienced exactly the same issue.
I am on BT infinity 1, but am experiencing speeds of that expected on BT infinity 2.
My speed test is over wifi and not from the hub (have the locked white openreach box so hub doesn't give me speeds). But on 2 seperate devices, I was getting approx 60 down / 18 up. Would be higher over ethernet. Clearly this is higher than the 55/10 I am supposed to get.
My HH5 has rebooted itself 3 times this week rather than the usual once every 14 days. Could have had the new speed then assigned then.
My original thread: https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-1-higher-than-expected-upload-s...
