Message 1 of 24
Speed just suddenly dropped.
DLS just disconnected and reconnected, now we're having horrible throughput.
BT speedtester doesn't complete anymore, says busy at end of test, but it confirms the profile is still 7150k.
Current throughput of a speed test that works: http://www.speedtest.net/result/1508199803.png
Current stats:
Line state:Connected
Connection time:0 days, 00:10:24
Downstream:7.938 Mbps
Upstream:448 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.1 Annex A
Latency type:Fast
Noise margin (Down/Up):7.5 dB / 29.0 dB
Line attenuation (Down/Up):28.8 dB / 15.5 dB
Output power (Down/Up):19.9 dBm / 12.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):16 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):35 / 0
Error Seconds (Local/Remote):11 / 1
23 REPLIES 23
Message 2 of 24
Re: Speed just suddenly dropped.
 IP Profile for your line is - 7150 Kbps
 Download speedachieved during the test was - 174 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Message 3 of 24
My speed has dropped dramatically now too. At 7.30 I the bt beta speedtester said i was getting 6.95Mbps, now I'm barely getting 400kbps. I'm in Livingston, Scotland.
Message 4 of 24
I should add that my ip profile remains unchanged at 7150Kps
Message 5 of 24
Same here.
Good, then all of a sudden bad upload.
Scotland, Edinburgh
No disconnection though.
Message 6 of 24
I live just north of newcastle so it's possible my route goes through scotland and the problem is there.
BT have posted an update of problems in Glasgow and have a 2 hour ETA, I'll check back in a bit.
Expert
Message 7 of 24
I just got a Speedtester result of 25K !  I think my lowest ever.
I am on 01397 in the Highlands.
A friend asked earlier if I had any speed problems but had not noticed anything at that time.
MB
MB
Tags (1)
Message 8 of 24
Same problems here Dumfriesshire Smiley Mad
Expert
Message 9 of 24
I notice the BT Status page just says reports of problems from a handful of telephone code areas
I get a bad feeling that it is like the problems earlier in the year when BT had no real idea of the scale of the problem.
I have not called the 0800 because I don't want to spend an hour on the phone to someone in India trying to convince me my equipment is faulty.
MB
Message 10 of 24
Just chiming in as I have had the same issue, had a disconnect around about 8:50 then broadband speed plummeted. Managed to get a couple of speed tests done and the first one clocked in at 61 kbps. Here's the latest:
FAQ
Results Image not loaded
This Test comprises of Best Effort Test: -provides background information.
 Download  Speed
 99 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 99 Kbps
 Your DSL Connection Rate :3776 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 3000 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit FAQ section if you are unable To understand the test results.
This comes after I had issues last weekend when my speed and profile dropped for no reason to 400-500kbps and only returned to my normal 2700kbps on monday. Not a happy bunny at the moment.
EDIT: Oh Elgin - Scotland. 01343.
