Message 1 of 4
Speed non existent last night
The internet speed dropped to nil last night.
Spped test result:
1. Best Effort Test:  -provides background information.
Download  Speed
0.08 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.08 Mbps
 For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
 IP Profile for your line is - 5.49 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.71 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.71Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
 It was ok at 7 am this morning but has gone again.
Here is the hub report:
ADSL Line Status
Connection information
Line state: Connected
Connection time: 9 days, 08:05:49
Downstream: 6,227 Kbps
Upstream: 835 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.5 Annex A
Latency type: Fast
Noise margin (Down/Up): 4.0 dB / 7.1 dB
Line attenuation (Down/Up): 48.5 dB / 27.4 dB
Output power (Down/Up): 0.0 dBm / 12.9 dBm
FEC Events (Down/Up): 0 / 0
CRC Events (Down/Up): 3800115 / 127
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
Loss of Link (Remote): 0
HEC Errors (Down/Up): 19790649 / 184
Error Seconds (Local/Remote): 0 / 75
 and again
ADSL Line Status
Connection time: 9 days, 08:33:54
Upstream: 835 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
Noise margin (Down/Up): 3.9 dB / 7.1 dB
CRC Events (Down/Up): 3903580 / 127
HEC Errors (Down/Up): 20944410 / 184
and again
ADSL Line Status
Upstream: 835 Kbps
  ADSL settings
VPI/VCI: 0/38
Type: PPPoA
Latency type: Fast
The line worked well after it was last reset but has gone completely haywire again. Can it be fixed?
3 REPLIES 3
Message 2 of 4
Re: Speed non existent last night
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 4
Yes that information is there
Message 4 of 4
are you connected to the test socket ?
have you tried the quiet line test ?
can you re run the speedtest during the day and post the results and also repost again at peak time tonight as the changes need to be seen posted here before things can be taken further to help you
