Greetings all, I hope theres someone who can help around here.
This connection has been troublesome for a couple of years now and I'd like advice on two fronts.
1) making sense of some of the stats I'm about to post so that its caused by what I think it is.
2) how do I get BT to recalculate my ip profile quickly? I'll Explain why below.
so, here are the numbers
BT speedtest
Download speedachieved during the test was - 119 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 250 Kbps
Speedtest.net
http://www.speedtest.net/result/1228706324.png
Router (v1, but v2 gave the same values)
All of my woes in the past have been caused by momentary interruptions to the line, which is to be expected in Rural Lincolnshire 2k from the phone exchange thats been stocked with ancient eqipment and connected with lines decades old to houses with decades old wiring.
the mometary interruptions seemed to cause the ip profile to go screwy so that the phone exchange refuses to relinquish download bandwidth to me, at my computer I am DLing at 15kbs
as you can see the upload speed is much faster than the download, and supports the notion that the line itself is capable of handling higher speeds.
The ping is an interesting consideration as its at 57ms, yesterday it was 250ms and would shoot up to 1000ms the second you actually tried doing anything.
this happens quite often as out here in the sticks power cuts and other interruptions are to be expected, and while it get frustrated at paying the same as a city go-er who gets 8MB broadband, I understand that BT can't be expected to provide perfect service in such a large sparsely populated area.
So, how do I deal with this? in teh past I've phoned up and had to do a song and dance routine to get to someone who would give me the number to the engineering dept so that someone with expertise can talk to me, who would promise to leave a call at the phone exchange for the guy to fix me up...thats alot of money down the drain on the call and alot of my time wasted just so that I can be told "please don't disconnect your router for 72hrs so that blah blah"
covering my bases (for anyone who thinks its a problem on my end)
tried different microfilters
3 different computers with different OS's, AVs etc all find same problem
2 different routers (both BT home hubs, one v1 and one v2)
tried reseting routers multiple times and to factory settings
router is in the master telephone socket which goes directly to the main line outside
right now performance is so low that I cannot watch a youtube video in real time with it on the lowest possible resolution (ordinarily I can watch one at 360, not great but acceptable.
If I leave the router plugged in and nothing interrupts it, then eventually this will fix itself, shortest time for this has been 12hrs, the longest has been 1 week. While the internet is indeed a source of great personal enjoyment for me and others in this household, its also something we came to rely on professionally and organisationally before we came to this house. a week where simply checking your e-mail takes 10x longer or viewing even a simple .jpeg file takes several minutes causes immense frustration and setback.
If anyone can help on any issue here, I would be most grateful.
Solved! Go to Solution.
As john46 says all the disconnections are the reason your noise marginis high. This has not been helped by all the things you have well meaningly tried to sort your connection but every change of filter, router change etc is causing another reset.
your profile is 250 but that's high for your speed so may well drop to 135 to match speed.
You say you are connected to the master socket but do you have a detachable bottom have with the test socket behind. if so and you have other extension sockets in your home then it would help if you connected to the test socket to eliminate any noise from your internal wiring.
you can also check this
http://community.bt.com/t5/BB-in-Home/Poor-Broadband-speed/m-p/14217#M8397
cheers, I've already tried that but thanks anyway
Well, I've applied for nursing and had 3 interviews, wish me luck that I can move to a city and away from the technological backdrop that is Lincolnshire 😛
Connection time 3 days, 17:05:16
still no progress
why do BT have to recalculate my IP profile anyway?
I mean...my possible max speed never changes so why not just leave it as a static number?
profile is based on your current speed as seen here http://www.kitz.co.uk/adsl/IPprofile.htm
can you post stats again if you want further help/suggestions
bt speedtest
Download speedachieved during the test was - 123 Kbps
router stats
Line state | Connected |
Connection time | 3 days, 17:37:18 |
Downstream | 160 Kbps |
Upstream | 448 Kbps |
http://www.speedtest.net/result/1232967973.png
can you post the rest of the stats which will include noise margin and errors
ADSL Settings | |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | G.992.1 Annex A |
Latency type | Interleaved |
Noise margin (Down/Up) | 19.0 dB / 13.0 dB |
Line attenuation (Down/Up) | 65.5 dB / 31.5 dB |
Output power (Down/Up) | 0.5 dBm / 1.1 dBm |
Loss of Framing (Local/Remote) | 0 / 0 |
Loss of Signal (Local/Remote) | 0 / 0 |
Loss of Power (Local/Remote) | 0 / 0 |
FEC Errors (Down/Up) | 3070 / 235 |
CRC Errors (Down/Up) | 1307 / 112 |
HEC Errors (Down/Up) | 620 / 71 |
Error Seconds (Local/Remote) | 912 / 82 |
