daveesh
Message 1 of 1
Speed reduced due to interleaving
Hi guys and girls wonder if anybody can shed some light on this 33 days ago I had interleaving applied to my line which reduced my speed to 44207 from around 48500. I am using a billion 8800axl apart from the SNR being reduced I can't see any reason why DLM should not of removed interleaving.Theres the stats from the modem
ModeVDSL2
Traffic TypePTM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)4.76.0
Attenuation (dB)22.40.0
Output Power (dBm)5.05.0
Attainable Rate (Kbps)486577440
Rate (Kbps)442077355
B (# of bytes in Mux Data Frame)51230
M (# of Mux Data Frames in an RS codeword)11
T (# of Mux Data Frames in an OH sub-frame)645
R (# of redundancy bytes in the RS codeword)1216
S (# of data symbols over which the RS code word spans)0.03740.9985
L (# of bits transmitted in each data symbol)136801979
D (interleaver depth)8651
I (interleaver block size in bytes)64247
N (RS codeword size)64247
Delay (msec)80
INP (DMT symbol)3.000.00
OH Frames1201559857176251264
OH Frame Errors237798
RS Words26565400361638047
RS Correctable Errors285341413723
RS Uncorrectable Errors1453960
HEC Errors347230
OCD Errors160
LCD Errors160
Total Cells8225736460
Data Cells6067592890
Bit Errors00
Total ES54793
Total SES00
Total UAS2626
