Message 1 of 1
Speed reducing during hot spell
I'm used to some fall off when the weather warms up, always get the best speeds in winter, but the fall off seems to have been particularly pronouced. The 4832kps was unusually high. Carried out a quiet line test, it is. The speed is still above minimum guarenteed, as that is grossly pessimistic for a 4km line. Profiled down to 1750kbps is pretty pathetic for shared household usage.
Any thoughts on anything that can be done other than wait for autumn?
13:08:23, 20 Jun.
(303423.420000) DSL noise margin: 13.00 dB upstream, 6.20 dB downstream
13:08:23, 20 Jun.
(303423.360000) DSL line rate: 448 Kbps upstream, 2304 Kbps downstream
03:12:16, 20 Jun.
(267656.700000) DSL noise margin: 17.00 dB upstream, 0.00 dB downstream
03:12:16, 20 Jun.
(267656.630000) DSL line rate: 448 Kbps upstream, 3104 Kbps downstream
03:09:38, 20 Jun.
(267498.540000) DSL noise margin: 17.00 dB upstream, 0.00 dB downstream
03:09:38, 20 Jun.
(267498.470000) DSL line rate: 448 Kbps upstream, 3040 Kbps downstream
14:23:22, 19 Jun.
(221523.210000) DSL noise margin: 7.00 dB upstream, 6.00 dB downstream
14:23:22, 19 Jun.
(221523.140000) DSL line rate: 160 Kbps upstream, 4288 Kbps downstream
00:52:21, 17 Jun.
( 88.000000) DSL noise margin: 17.00 dB upstream, 6.10 dB downstream
00:52:21, 17 Jun.
( 87.790000) DSL line rate: 448 Kbps upstream, 4448 Kbps downstream
19:02:58, 15 Jun.
(1036327.120000) DSL noise margin: 16.00 dB upstream, 6.00 dB downstream
19:02:58, 15 Jun.
(1036327.050000) DSL line rate: 448 Kbps upstream, 4768 Kbps downstream
17:42:10, 15 Jun.
(1031478.990000) DSL noise margin: 16.00 dB upstream, 6.10 dB downstream
17:42:10, 15 Jun.
(1031478.920000) DSL line rate: 448 Kbps upstream, 4832 Kbps downstream
