Message 1 of 6
Speed stuck on 25.65mb down and 5.95mb up
After a new modem my speed seems to be capped at 25.65mb download and 5.95 upload.
before I was getting 37mb download constant and 8mb upload.
Ping is higher aswell from 8 to 15/16 now.
Tags (2)
5 REPLIES 5
Moderator-Retired
Message 2 of 6
Re: Speed stuck on 25.65mb down and 5.95mb up
Hi Rhydian,
If you're still having problems, fill out our webform (you can find the link under "about me" in my profile) and I'll have a look into this for you.
Cheers
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Recognised Expert
Message 3 of 6
My speed has dropped after a power cut last week and a drop out (very unusual) on Monday. No sign of the speed recovering . . . Used to be 30/8.
Recognised Expert
Message 4 of 6
Getting slower and slower . . . (tested on Ethernet!)
Recognised Expert
Message 5 of 6
As per many other posts, the BT speedtester is borked (again), so no longer able to check. Had a couple of further disconnections. Openreach modem is no hotter than normal, don't think the problem is here.
Recognised Expert
Message 6 of 6
Speedtester working again.
More weirdness. Profile has dropped further, but download speed is slightly higher!
