Paul_Cullen
Message 1 of 12
Speed very slow and keeps dropping the connection (sometimes)
I know this is a frequentl topic I have gone through all the fixes and countermeasures of previous messages.
My down loads speed is 0.25MPS and upload 0.67Mps ping latency ms 50.75.
I have a hub3 connected via a BT filter to a BT open reach socket.
The Hub is on 24/7.
I have tried connecting via the test socket, checked the wiring without any improvement.
The annoying thing is that sometimes the broadband remains connected at other times it drops frequently (every couple of minutes).
What can I try next?
11 REPLIES 11
Message 2 of 12
Re: Speed very slow and keeps dropping the connection (sometimes)
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Paul_Cullen
Message 3 of 12
Thanks for the response
Here is the speed test result:
Best Effort Test: -provides background information.
 Download  Speed
 0.24 Mbps
0 Mbps0.25 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.24 Mbps
 For your connection, the acceptable range of speeds is 0.1 Mbps-0.25 Mbps.
 IP Profile for your line is - 0.25 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.65 Mbps
0 Mbps0.83 Mbps
Upload speed achieved during the test was - 0.65Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
The hub ADSL data is here:
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 12:23:37
Downstream:287.1 Kbps
Upstream:888.9 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):16.2 dB / 13.2 dB
Line attenuation (Down/Up):35.5 dB / 21.3 dB
Output power (Down/Up):18.2 dBm / 12.4 dBm
FEC Events (Down/Up):17094 / 2751
CRC Events (Down/Up):20 / 58
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):78 / 155
Error Seconds (Local/Remote):4 / 18
Message 4 of 12
Due to hub disconnections /restarts you are in a banded profile.  you now need to maintain  a stable connection with no hub restarts for the next 3/5 days and you should then lift out of the banding automatically
This link explains more http://forumhelp.dyndns.info/speed/speed_drop.html
Paul_Cullen
Message 5 of 12
Thanks for the help I will see how it goes over the comming days.
Message 6 of 12
ok post back after 3/5 days and repost the adsl stats then and if needed further help can be obtained
Paul_Cullen
Message 7 of 12
It looks like I have a line problem as the connection keeps dropping.  When I checked the ADS stats this morning having had the router connected 24/7 it showed a connection time of 1 hour 47 minutes and then dropped the connecetion as I was watching the ADS stats.
I think the line problem is weather related as today it is wet and windy.
Do you know how to get this type of problem fixed?
Message 8 of 12
Have you tried the quiet line test dial 17070 option 2 you should hear no noise any noise heard should be reported to BT Faults on 151 with no mention of broadband in the call
Paul_Cullen
Message 9 of 12
Thanks for the reply.  The quiet test came up OK.
I have now had a stable broad band connection with no drop outs for more that a day through the test socket.
It looks like my speed has been capped by BT as a result of previous drop outs.
I am going to leave it in the test socket for a few days to see if the cap comes off.
Is there any problems with using the test socket?
What is the difference between the tes socket and the normal socket?
Message 10 of 12
perfectly ok to leave it in the test socket the test socket is a direct connection to the exchange were the master socket has any extensions connected to it and it eliminates any internal problems
