jonsmile
Message 1 of 8
Speed
At inlaws and their infinity speed is lower than expected
is is this going to be part of the issue. This is the picture of the phone pole at the end of the driveway.
7 REPLIES 7
jonsmile
Message 2 of 8
Re: Speed
Product name: BT Home Hub
2. Serial number: +068543+NQ41809228
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 04/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 4 days, 21:39:25
6. Data rate: 9995 / 39993
7. Maximum data rate: 20401 / 67520
8. Noise margin: 13.0 / 14.6
9. Line attenuation: 20.1 / 18.0
10. Signal attenuation: 19.9 / 17.9
jonsmile
Message 3 of 8
Re: Speed
Telephone Number on Exchange FAREHAM is served by Cabinet 53
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 68.8 53.1 19.8 13.3 -- Available
FTTC Range B (Impacted) 51.4 31 14.9 6.6 -- Available
WBC ADSL 2+ Up to 17.5 --
licquorice
Message 4 of 8
Re: Speed
Looks like they are on Infinity 1 and running at maximum speed.
jonsmile
Message 5 of 8
Re: Speed
So why is box 7 showing 70 meg? Thought that wss the max possible?
licquorice
Message 6 of 8
Re: Speed
Infinity 1 is capped at 40/10 Infinity 2 is capped at 80/20. If they have Infinity 1 they are at max for that product. They would get 70 if they had Infinity 2.
licquorice
Message 7 of 8
Re: Speed
Unless your in-laws habitually stream multiple HD channels or download multi GB files there would be no point in upgrading to Infinity 2
If you carry out the speedtest here and then enter their phone number and complete the further diagnostics you can tell by the upstream IP profile if they have Infinity 1 (10) or Infinity 2 (20)
Webby
Message 8 of 8
Re: Speed
As above, that's the max the line can support. As they're on Infinity 1, Openreach set a soft "cap" at the cabinet equipment to "limit" the connection speed at 40meg (line 6 shows 39993 - 40meg).
