endadmcc
Message 1 of 5
Speeds getting lower every week
Connection information<script type="text/javascript"></script>
Line stateConnected
Connection time2 days, 8:04:56
Downstream640 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript"></script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)18.3 dB / 15.0 dB
Line attenuation (Down/Up)61.0 dB / 31.5 dB
Output power (Down/Up)15.4 dBm / 12.1 dBm
Loss of Framing (Local)20
Loss of Signal (Local)6
Loss of Power (Local)0
FEC Errors (Down/Up)1944 / 176
CRC Errors (Down/Up)5 / 2147480000
HEC Errors (Down/Up)nil / 89
Error Seconds (Local)3094
This is my speed info today and below is the speed info on the 17/01/11
line state   connected
connection time   1 day 22.34.12
downstream     2,432 kbps
upstream   448 kbps
vpi/vci 0/38
type pppoa
modulation 1tu-tg.992.1
latency type  interleaved
noise margin   6.7db/15.0db
line attenuation   61.0db/31.5db
output power  17.8dbm/12.3 dbm
loss of framing   23
loss of signal   2
loss of power   0
fec errors  3149713/83
crc errors  4662/2147480000
hec errors   nil/48
error seconds  984
I noticed the noise margin has gone up is this causing  the speed problem?
Also my brother lives a short distance away and is on the same bt line and he is having similar problems.
Is there any telephone number for bt that i can ring to complain about the speed i am getting  and to check if there is a problem with the line ?
 The connection is cutting on and off on its own every other day so the connection times are low.
4 REPLIES 4
Message 2 of 5
Re: Speeds getting lower every week
check your exchnage here http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
endadmcc
Message 3 of 5
Thanks for the links but everything seems ok at my exchange.
Message 4 of 5
customer service is 08001114567
make sure you are connected to the master or preferably test socket before you phone India as that is first question they will ask
endadmcc
Message 5 of 5
OH no not India i thought i had got away from them when i left orange not being racist but they cant understand me and i cant understand them.
