A_mars_reject
Message 1 of 6
Speedtester says fast, downloading says slow
Hi,
I have been having frequent problems both with stability and broadband speed. This week the guys at the exchange have reset my profile again and the connection has been stable, but the speed has been slow. To clarify, I have run speedtester.bt.com, and it says Down: 359kbps, Up: 335kbps, and I have checked the hub manager, which says Downstream 1,984kbps, Upstream 448kbps.
Both of these would sugget to me that the speed should be fine (if I'm wrong, please let me know, I'm pretty amateur at this), yet anything I download is still very slow.
e.g. Steam downloads at a max of around 60kbps, normally around 220 at good speeds. The Youtube clip I use to test this keeps buffering frequently, while at good speeds it would play through smoothly. iTunes podcasts take at least 3 times as long. Flash upgrade takes around 5 mins.
I've had this slowness frequently in the past, but not when all the indicators have said it should be fine. Could anyone suggest what may be causing this, and what could be done to fix it, short of the call centre?
Many thanks,
James Carter
5 REPLIES 5
Geoff93
Recognised Expert
Message 2 of 6
Re: Speedtester says fast, downloading says slow
If you post the stats from your router
192.168.1.254
Navigate to ADSL Settings or use the A-Z at the top right
Click on More Details and then post the results.
And post the results from http://speedtester.bt.com/
then someone may be able to help.
A_mars_reject
Message 3 of 6
Here's the Hub details:
Connection information<script type="text/javascript">// createTable("normal", trClass, td1, td2); // </script>
Line stateConnected
Connection time0 days, 0:05:48
Downstream1,920 Kbps
Upstream448 Kbps
ADSL settings<script type="text/javascript">// createTable("normal", trClass, td3, td4); // </script>
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)18.6 dB / 13.0 dB
Line attenuation (Down/Up)54.0 dB / 31.5 dB
Output power (Down/Up)17.5 dBm / 12.7 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)1440 / 0
CRC Errors (Down/Up)8 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)2
and the speedtester:
FAQ
Results Image not loaded
<script type="text/javascript"></script> Test1 comprises of two tests
1. Best Effort Test: -provides background information.
Download Speed
376 Kbps
0 Kbps500 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 376 Kbps
 For your connection, the acceptable range of speedsis 100-500 Kbps.
 Additional Information:
 Your DSL Connection Rate :1920 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 14.77:22.86:62.37 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
2. Upstream Test: -provides background information.
Upload Speed
335 Kbps
0 Kbps448 Kbps
>Upload speed achieved during the test was - 335 Kbps
 Upstream Rate IP profile on your line is - 448 Kbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit FAQ section if you are unable To understand the test results.
A_mars_reject
Message 4 of 6
As an update, it seems I'm still suffering random dropouts, which was solved after restarting and resetting the Hub (v.2), but it's still unacceptable to keep suffering fairly frequent dropouts after over 6 months of trying to get this solved by the call centre.
The engineer has been out and checked all the local equipment (no problems there) and determined that the problem keeps arising at the exchange, I just don't understand why it can't be fixed for good.
A_mars_reject
Message 5 of 6
Now it's just being silly. A couple of brief dropouts then back to blue, but now my speed has truly plummeted, and the hub says:
Line stateConnected
Connection time0 days, 2:27:48
Downstream288 Kbps
Upstream448 Kbps
VPI/VCI0/38
TypePPPoA
Noise margin (Down/Up)32.4 dB / 15.0 dB
Output power (Down/Up)14.8 dBm / 12.7 dBm
FEC Errors (Down/Up)3179 / 14
CRC Errors (Down/Up)326 / 2147480000
HEC Errors (Down/Up)nil / 12
Error Seconds (Local)221
I'm sorry, but what kind of useless broadband service is this that keeps dropping out, slowing down, and needs the profile resetting every week? Can anyone tell me how to get this fixed for good?
Tags (1)
A_mars_reject
Message 6 of 6
Restarted the hub and the Speed has gone up again:
Line state Connected
Connection time 0 days, 0:22:48
Downstream 2,240 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Interleaved
Noise margin (Down/Up) 15.0 dB / 15.0 dB
Line attenuation (Down/Up) 54.0 dB / 31.5 dB
Output power (Down/Up) 16.9 dBm / 12.6 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
Loss of Power (Local) 0
FEC Errors (Down/Up) 34 / 0
CRC Errors (Down/Up) 1 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 1
Still don't understand why it's so ephemeral, though 😞
