oldfruit
Message 1 of 2
Spell Check
Hello There,
Does anyone know if there is a Spell Check facility for e mails.
I've contacted BT Help,they say it dosen't exist anymore ,which i can't believe.
Thanks in advance
Dave Williams
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Spell Check
I have spellcheck with both my email client (Thunderbird) and BT Yahoo! webmail (which I rarely use). Assuming you are referring to webmail, in the "compose" box there is a button on the toolbar marked with "abc" and a red tick. That's the spellcheck button; also, misspelt words are automatically underlined in red as I type.
I'm still using Classic Mail, having declined to upgrade to the newest version. I would expect the new one to have at least the same features but can't be sure about that.
Edit: Thunderbird has options to turn specllcheck features on or off, but I can't find any similar options in BT Yahoo! webmail - it's always on.
Where exactly are you having the problem?
