Message 1 of 8
Splitter for DV hub output. Feasible?
Changeover to DV was a couple of weeks ago. I bought a set of BT premium phones but have had many problems getting them to do anything more than make and receive calls.
Out of interest, I plugged my trusty Panasonic base unit into the hub. It worked, as did its 3 satellite phones.
So I could have 3 reliable traditional phones working or 3 new BT phones, not working to their potential. And my wife prefers the BT ones.
But what if I plugged a BT splitter into that green socket? I had one, I did it and it seems to work!!!!!!
Obviously only one answer machine could be on at a time but could there be hidden pitfalls to this?
7 REPLIES 7
Message 2 of 8
Re: Splitter for DV hub output. Feasible?
@SlowRob
I cannot see any issues with a splitter, as modern phones only use a tiny amount of current from line, and need very little incoming ringing voltage.
Message 3 of 8
@SlowRob
are the premium phones you bought for DV or normal connection to socket as normally you get either 2 essential or 1 advanced phone on changeover to DV
Message 4 of 8
I opted for one advanced DV phone. It also works at the same time, since it doesn't use a wired connection to the hub, but does seem to conflict with the premium phones. It is difficult to hear what the voice is complaining about, with 7 phones ringing in the house 🙂 🙂
Message 5 of 8
Message 6 of 8
not actually for DV but look very similar to the DV advanced phone prior to addition of Alexa
Message 7 of 8
"Not for DV"! Funny, that wasn't mentioned in BT adverts, or by BT staff I spoke to.
Message 8 of 8
probably no mention o f DV as the vast majority of BT customers do not have DV
