Message 1 of 7
Splitting Wireless Bands on BT Homehub 6
Hi, Over the years I have successfully splits the wireless bands on a BT homehub 6, however when I tried to spilt the 2.4 and 5GB channels, on my daughters hub the " Separate Bands button is missing.
I went in to Wireless, Change Settings, enter Admin password, the Separate Bands button is missing. Can anyone please help.
6 REPLIES 6
Message 2 of 7
Re: Splitting Wireless Bands on BT Homehub 6
If it's the SH2, you can't split the bands.
Message 3 of 7
Hi, thanks for your reply, I thought all Hub 6's had the facility to have the channels split. This hub is approx. 2 years old. How do I know if it is the SH2
Message 4 of 7
It will say Smart Hub 2 at the top of the page
Message 5 of 7
Hi
It says BT Smart Hub Manager
Message 6 of 7
as long as it does not say Smart hub 2 manager then go to hub manager then try advanced settings then wireless then change settings and see if that allows you to split network
Message 7 of 7
Hi
Thanks, I have successfully split the channels.
