Message 11 of 17
Re: Standard "when can I get fibre?" post, with a less common twist...
Hi Neil, Thanks for your reply. I'm really sorry, and forgive me if I'm being a biff, but I can't find the 'contact the mods' link or 'contact us' link anywhere in your profile. I'm signed into the forum, and I've used IE's 'find on this page' in case I was just missing it, but I can't find the link. Would it be possible for you to PM me the URL and I'll follow it through that way? Thanks.
Moderator-Retired
Message 12 of 17
Hi awittyusername,
Sorry about that Smiley Embarassed
Try the link on my profile now and let me know if you are still having problems.
Cheers,
OlgaC
Message 13 of 17
Thanks Olga, I've completed the form but only put a very basic outline in the 'query' box since this thread URL is on there too. I hope this is OK? Regards, Michael
Message 14 of 17
Olga,
I'm having some problems emailing you back. When I try to I get an automated response saying I'm not using the email address from which I registered with. I am emailing from a military network so it needs to go through a gateway to get out which might modify the way it appears on your systems. To get around this I changed my email address in the forum to another one that I can use, but I'm getting the same message as I suspect it's checking my email address against the one that you originally sent the email to.
Can you please resend your email to me to the address that I have updated in my profile and hopefully this will allow me to reply?
Thanks,
Michael
Sage
Message 15 of 17
Have submitted the form or is that what you are having problems with?
Message 16 of 17
I've informed Olga of your problem.
Moderator
Moderator
Message 17 of 17
Hi awittyusername,
Sorry about that. Olga has resent the email.
Cheers
Neil
