Message 1 of 5
Static Router IP with 5 static IP addresses
I have a Tomato USB Router connected and working well. I also have 5 static IPs that are routing fine to internal servers on my LAN. The problem I have is that PC's on my LAN are going out on the dynamic IP address that the modem provides - and this changes.
Does anyone know how to configure Tomato to present itself as one of the static IP addresses externally?
4 REPLIES 4
Distinguished Expert
Message 2 of 5
Re: Static Router IP with 5 static IP addresses
You could change to Infinity for Business and get a static IP.
Message 3 of 5
Sorry - I am on Infinity for Business. I spoke with BT and they said if I downgraded to 1 static IP it would work but with 5 I have to use the dynamic one, but they said for some (unsupported) routers you can set it to go out as one of the 5 static but I can't see where I'd do that...
Message 4 of 5
Message 5 of 5
OK Thanks
